Product Flyer MLX81116 (Melexis)
ManufacturerMelexis
DescriptionMulti-Channel RGB-LED Driver
Pages / Page2 / 1 — MLX81116. HIGH-SPEED. ANIMATED LIGHTING. SMART MULTI-CHANNEL (RGB)-LED …
File Format / SizePDF / 401 Kb
MLX81116. HIGH-SPEED. ANIMATED LIGHTING. SMART MULTI-CHANNEL (RGB)-LED DRIVER. ENABLES HIGH-SPEED LIGHT ANIMATIONS. KEY FEATURES
Product Flyer MLX81116 Melexis
ence. efer
MLX81116
esponse to er’s pr e link these wonderful efor MULTI-CHANNEL (RGB)-LED DRIVER e ther oducts which enable changing GB pr ding to the car driv
HIGH-SPEED
e famous for their quick skin color- es to our LIN R
ANIMATED LIGHTING
onmental changes. W vir eatur Chameleons ar changing abilities. They change color in r en cr ambient light accor
SMART MULTI-CHANNEL (RGB)-LED DRIVER ENABLES HIGH-SPEED LIGHT ANIMATIONS
The MLX81116 is a fully integrated smart automotive LED driver with high-speed robust communication (MeLiBu™) between multiple LED drivers to enable applications with high LED counts for highly animated light applications. All necessary components needed for LED driving as well as communication are integrated and allow to develop powerful and cost-optimized animated light systems. For applications requiring RGB-LEDs, the embedded intelligence allows a very high accuracy of the needed color mixing. ASIL-B grade applications are supported as well thanks to the MeLiBu™ communication system.
KEY FEATURES
k MCU for extended LED control algorithm, color k Direct and multiplex LED drive without additional mixing and full diagnosis external components k Red/Green and Blue LED temperature compensation k LEDs fully diagnosable (Short circuit, broken line, without additional external components threshold monitor) k Color mixing accuracy of < 1% delta UV k MeLiBu ™ communication interface k 16-bit color/intensity control k Real-time update of > 250 RGB LEDs without delay k Storage of LED calibration data directly within k 5.5 - 18 V supply voltage (40 V proof) LED driver k ASIL B classification k Low side programmable calibrated current k QFN4x4 package, 24 pins sources for LED control
KEY APPLICATIONS
k Highly animated light modules k Smart light bar k Advanced driver communication by light • Safety warning applications • Advanced navigation support • Blindspot warning
FOR MORE INFORMATION: WWW.MELEXIS.COM/MLX81116
