Datasheet AOZ5317UQI (Alpha & Omega) - 7
ManufacturerAlpha & Omega
DescriptionHigh-Current, High-Performance DrMOS Power Module
Pages / Page17 / 7 — AOZ5317UQI. Electrical Characteristics(4). Symbol. Parameter. Conditions. …
AOZ5317UQI. Electrical Characteristics(4). Symbol. Parameter. Conditions. Min. Typ. Max. Units. GATE DRIVER TIMING. THERMAL NOTIFICATION
AOZ5317UQI Electrical Characteristics(4) Symbol Parameter Conditions Min Typ Max Units GATE DRIVER TIMING THERMAL NOTIFICATION
TJ = 0°C to 150°C. Typical values reflect 25°C ambient temperature; VIN = 12V, VOUT = 1V, PVCC = VCC = DISB# = 5V, unless otherwise specified. Min/Max values are guaranteed by test, design, or statistical correlation.
Symbol Parameter Conditions Min. Typ. Max. Units GATE DRIVER TIMING
tPDLU PWM to High-Side Gate PWM: H  L, VSWH: H  L 24 ns tPDLL PWM to Low-Side Gate PWM: L  H, GL: H  L 25 ns tPDHU LS to HS Gate Deadtime GL: H  L, VSWH: L  H 15 ns tPDHL HS to LS Gate Deadtime VSWH: H  1V, GL: L  H 13 ns PWM: L  V t TRI, GL: H  L and TSSHD Tri-State Shutdown Delay 25 ns PWM: H  VTRI, VSWH: H  L PWM: V t TRI  H, VSWH: L  H TSEXIT Tri-State Propagation Delay 35 ns PWM: VTRI  L, GL: L  H tLGMIN LS Minimum On Time SMOD# = L 350 ns
TJTHWN Junction Thermal Threshold Temperature Rising 150 °C TJHYST Junction Thermal Hysteresis 30 °C VTHWN THWN Pin Output Low ITHWN = 0.5mA 60 mV RTHWN THWN Pull-Down Resistance 120 Ω
Notes:
4. All voltages are specified with respect to the corresponding AGND pin. 5. Characterization value. Not tested in production. Rev. 2.0 June 2020
www.aosmd.com
Page 7 of 17
