Datasheet IR11-21C/TR8 (Everlight) - 7
Manufacturer | Everlight |
Description | 1206 Package Chip Infrared LED With Inner Lens |
Pages / Page | 9 / 7 — Data Sheet. 1206 Package Chip Infrared LED With Inner Lens IR11-21C/TR8. … |
File Format / Size | PDF / 322 Kb |
Data Sheet. 1206 Package Chip Infrared LED With Inner Lens IR11-21C/TR8. Revision : 4. Release Date:2015-10-16 11:07:50.0
Data Sheet 1206 Package Chip Infrared LED With Inner Lens IR11-21C/TR8
4.Soldering Iron Each terminal is to go to the tip of soldering iron temperature less than 350℃ for 3 seconds within once in less than the soldering iron capacity 25W. Leave two seconds and more intervals, and do soldering of each terminal. Be careful because the damage of the product is often started at the time of the hand solder. 5.Repairing Repair should not be done after the LEDs have been soldered. When repairing is unavoidable, a double-head soldering iron should be used (as below figure). It should be confirmed beforehand whether the characteristics of the LEDs will or will not be damaged by repairing. 7 Copyright © 2015, Everlight All Rights Reserved. Release Date: 2015/9/26. Issue No:DIR-0000945. Rev: 4 www.everlight.com
Revision : 4 Release Date:2015-10-16 11:07:50.0 LifecyclePhase: Expired Period: Forever
