Datasheet MAX4230, MAX4231, MAX4232, MAX4233, MAX4234 (Maxim) - 5
Manufacturer | Maxim |
Description | High-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amps with Shutdown in SC70 |
Pages / Page | 15 / 5 — Typical Operating Characteristics. GAIN AND PHASE vs. FREQUENCY. L = … |
File Format / Size | PDF / 1.9 Mb |
Typical Operating Characteristics. GAIN AND PHASE vs. FREQUENCY. L = 250pF). POWER-SUPPLY REJECTION RATIO. vs. FREQUENCY
MAX4230–MAX4234 High-Output-Drive, 10MHz, 10V/μs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
(VDD = 2.7V, VSS = 0V, VCM = VDD/2, VOUT = VDD/2, RL = ∞, connected to VDD/2, VSHDN = VDD, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE vs. FREQUENCY GAIN AND PHASE vs. FREQUENCY (C
70 MAX4230 toc01 120
L = 250pF)
70 MAX4230 toc02 120 60 90 60 90 50 60 50 60 40 30 40 30 30 0 30 0 20 -30 20 -30 GAIN (dB) 10 PHASE (°) -60 GAIN (dB) 10 -60 PHASE (°) 0 -90 0 -90 -10 -120 -10 -120 A -20 AV = 1000V/V -150 V = 1000V/V -20 CL = 250pF -150 -30 -180 0.01k 0.1k 1k 10k 100k 1M 10M 100M -30 -180 0.01k 0.1k 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz)
POWER-SUPPLY REJECTION RATIO vs. FREQUENCY OUTPUT IMPEDANCE vs. FREQUENCY
1000 0 -10 ) 100 MAX4230 toc04 MAX4230 toc03 -20 Ω -30 -40 10 -50 1 PSRR (dB) -60 -70 OUTPUT IMPEDANCE ( -80 0.1 A -90 A V = 1V/V V = 1V/V 0.01 -1000.01k 0.1k 1k 10k 100k 1M 10M 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz)
SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE
2.0
(SHDN = LOW)
110 1.8 1.6 MAX4230 toc05 100 MAX4230 toc06 1.4 1.2 90 1.0 80 0.8 0.6 SUPPLY CURRENT (mA) 70 SUPPLY CURRENT (nA) 0.4 0.2 60 SHDN = VSS 0 -40 -20 0 20 40 60 80 100 120 50 -40 -20 0 20 40 60 80 100 120 TEMPERATURE (°C) TEMPERATURE (C) www.maximintegrated.com Maxim Integrated │ 5
