Datasheet MLX75026 (Melexis) - 4
Manufacturer | Melexis |
Description | QVGA Time-of-Flight Sensor |
Pages / Page | 64 / 4 — MLX75026 QVGA Time-of-Flight Sensor. Document Revision History. Version. … |
File Format / Size | PDF / 3.1 Mb |
MLX75026 QVGA Time-of-Flight Sensor. Document Revision History. Version. Date. Changes
link to page 12 link to page 14 link to page 16 link to page 18 link to page 27 link to page 30 link to page 33 link to page 38 link to page 36 link to page 41 link to page 54 link to page 62 link to page 63
PRELIMINARY DATASHEET
Document Revision History Version Date Changes
0.1-0.4 / Draft versions Description: Update product picture Section 3.6: Modified decoupling recommendations Section 3.9: Correction default slave address 0x67 to 0x57 Section 4.2: Note UV dosis reference for microlens + updated AC demod. contrast Section 4.4: Added MTF graph Section 6.2: Update to Initialization Register Map Section 7.1: Additional registers added for MIPI data rate configuration 0.5 11/09/2020 Section 7.2: Added entering streaming triggers a frame Section 7.4.2 & 7.12 : Rework of PIXRST & Px_PRETIME definition to PRETIME Section 7.8: Rework of frame time calculations Section 7.14: Removal of note Section 8: Added META_LENGTH control register Section 10.4: Updated coating type marking Section 10.5: Added cover tape removal instructions Update to first page disclaimer Table 1 : Changelog Preliminary Datasheet v0.5 Page 4 of 64 Document Outline Table of Contents Document Revision History Ordering Information 1. System Architecture 2. Sensor Block Diagram 3. Electrical Specifications 3.1. Absolute Maximum Ratings 3.2. Typical Operating Conditions 3.3. Video Interface 3.3.1. MIPI DC specification 3.3.2. MIPI AC specification 3.4. Power Consumption 3.5. Maximum Distance Frame Rate 3.6. Decoupling Recommendations 3.7. Power-up Sequence 3.8. Input Clock Requirements 3.9. I2C Specifications 4. Optical Characteristics 4.1. QVGA Pixel Array Configuration 4.2. Pixel & Image Array Characteristics 4.3. CRA (Chief Ray Angle) 4.4. MTF (Modulation Transfer Function) 4.5. Application Lens Design Recommendations 5. Communication Interface(s) 5.1. I2C (Inter-Integrated Circuit) 5.1.1. I2C Timing Sequence 5.1.2. Single I2C Read 5.1.3. Sequential I2C Read 5.1.4. Single I2C Write 5.1.5. Sequential I2C Write 5.1.6. I2C Slave Address 5.2. MIPI Alliance CSI-2 Description 5.2.1. Packet Structure 5.2.2. Data Format RAW12 5.2.2.1. Data Format in 4 Lane MIPI Configuration 5.2.2.2. Data Format in 2 Lane MIPI Configuration 6. Start-up Sequence 6.1. Initialization Process 6.2. Initialization Register Map 7. Register Settings 7.1. Video Output Configuration 7.2. Modes of Operation 7.3. Data Output Modes 7.4. HMAX & Frame Read-Out Time 7.4.1. PLLSSETUP 7.4.2. PRETIME 7.4.3. RANDNM0 7.5. PARAM_HOLD 7.6. USER_ID Register 7.7. Modulation Frequency 7.8. Frame Structure & Frame Rate 7.9. FRAME_STARTUP 7.10. FRAME_TIME 7.11. PHASE_COUNT 7.12. Px_PREHEAT, Px_PREMIX 7.13. Px_INTEGRATION 7.14. Px_PHASE_SHIFT 7.15. Px_PHASE_IDLE (or V-blanking) 7.16. Px_LEDEN 7.17. Px_DMIX0, Px_DMIX1 & Px_STATIC_LED 7.18. Analog Delay Setting 7.18.1. Coarse Delay 7.18.2. Fine Delay 7.18.3. Super Fine 7.19. Pixel Binning 7.20. Region of Interest (ROI) 7.21. Flip & Mirror 7.22. Temperature Sensor 7.23. Pixel & Phase Statistics 7.24. PN9 Test Pattern 7.25. Duty Cycle Adjustment 7.26. Illumination Signal (subLVDS or CMOS) 8. MetaData Description 8.1. Embedded Data Format in 4 Lane MIPI Configuration 8.2. Embedded Data Format in 2 Lane MIPI Configuration 9. Distance & Amplitude Calculation 10. Package Outline 10.1. Pinout & Equivalent I/O Circuitry 10.2. Mechanical Dimensions 10.3. PCB Landing Pattern & Layout Recommendations 10.4. Package Marking 10.5. Cover Tape Removal Disclaimer
