Datasheet AP4405AEN (Asahi Kasei Microdevices) - 4
ManufacturerAsahi Kasei Microdevices
DescriptionUltra-Low Power Voltage Detector with P and N-Channel MOSFET Switch
Pages / Page19 / 4 — 5. Pin Configuration and Function. 5.1. 5.2
File Format / SizePDF / 972 Kb
5 Pin Configuration and Function 5.1 5.2
[AP4405AEN]
5. Pin Configuration and Function 5.1
Pin Configuration ・16-pin HWQFN TOP View
5.2
Function Pin # Name I/O Function 1 NC - Not Connected 2 OUT Output Logic output 3 NC - Not Connected 4 VDD Power Power supply 5 PMOSD Input/Output PMOS drain pin 6 NC - Not Connected 7 NMOSD Input/Output NMOS drain pin 8 VSS Ground Ground 9 POL Input Polarity cotrol pin. Do not set this pin in the floating state. 10 TEST1 - For test purposes. This pin should be connected to VSS. 11 NC - Not Connected 12 TEST2 - For test purposes. This pin should be connected to VSS. 13 TEST3 - For test purposes. This pin should be connected to VSS. 14 TEST4 - For test purposes. This pin should be connected to VSS. 15 TEST5 - For test purposes. This pin should be connected to VSS. 16 VIN Power Detection voltage input pin Connecting the exposed pad that is located on the - TAB - bottom of the package(EPAD) to VSS is recommended. The pad can be left floating if needed. 019001973-E-00 2019/3 - 4 -
