Datasheet ICL761X, ICL762X, ICL763X, ICL764X (Maxim) - 5
Manufacturer | Maxim |
Description | Single/Dual/Triple/Quad Operational Amplifiers |
Pages / Page | 26 / 5 — Single/Dual/Triple/Quad. Operational Amplifiers. ICL761X–ICL764X. … |
File Format / Size | PDF / 524 Kb |
Single/Dual/Triple/Quad. Operational Amplifiers. ICL761X–ICL764X. ELECTRICAL CHARACTERISTICS (Single/Dual) (continued)
Single/Dual/Triple/Quad Operational Amplifiers ICL761X–ICL764X ELECTRICAL CHARACTERISTICS (Single/Dual) (continued)
(VSUPP = ±1.0V, IQ = 10µA, TA = +25°C, unless otherwise noted.)
ICL76XXA ICL76XXB PARAMETER SYMBOL CONDITIONS UNITS MIN TYP MAX MIN TYP MAX
VO = ±0.1V, RL = 1MΩ, 90 90 TA = +25°C Large-Signal Voltage A dB Gain VOL VO = ±0.1V, RL = 1MΩ, 80 80 0°C ≤ TA ≤ +70°C Unity-Gain GBW 0.044 0.044 MHz Bandwidth Input Resistance RIN 1012 1012 Ω Common-Mode CMRR RS ≤ 100kΩ 80 80 dB Rejection Ratio Power-Supply PSRR RS ≤ 100kΩ 80 80 dB Rejection Ratio Input-Referred Noise en RS = 100Ω, f = 1kHz 100 100 nV/√Hz Voltage Input-Referred Noise in RS = 100Ω, f = 1kHz 0.01 0.01 pA/√Hz Current Supply Current (Per ISUPP No signal, no load 6 15 6 15 µA Amplifier) A Slew Rate SR VOL = 1, CL = 100pF, VIN = 0.2VP-P, RL = 1MΩ 0.016 0.016 V/µs V Rise Time t IN = 50mV, CL = 100pF, r RL = 1MΩ 20 20 µs V Overshoot Factor IN = 50mV, CL = 100pF, RL = 1MΩ 5 5 %
(VSUPP = ±5.0V, TA = +25°C, unless otherwise noted.)
ICL76XXA ICL76XXB ICL76XXD PARAMETER SYMBOL CONDITIONS UNITS MIN TYP MAX MIN TYP MAX MIN TYP MAX
RS ≤ 100kΩ, 2 5 15 TA = +25°C Input Offset V mV Voltage OS RS ≤ 100kΩ, T 3 7 20 MIN ≤ TA ≤ TMAX Temperature ∆VOS/∆T RS ≤ 100kΩ 10 15 25 µV/°C Coefficient of VOS TA = +25°C 0.5 30 0.5 30 0.5 30 C: 0°C ≤ TA ≤ 300 300 300 +70°C Input Offset IOS E: -40°C ≤ TA ≤ pA Current 800 800 800 +85°C M: -55°C≤ TA ≤ 800 800 800 +125°C
_______________________________________________________________________________________ 5
