Datasheet MAX317, MAX318, MAX319 (Maxim) - 2
ManufacturerMaxim
DescriptionPrecision, CMOS Analog Switches
Pages / Page12 / 2 — Precision, CMOS Analog Switches. ABSOLUTE MAXIMUM RATINGS. Note 1:. …
File Format / SizePDF / 134 Kb
Precision, CMOS Analog Switches. ABSOLUTE MAXIMUM RATINGS. Note 1:. ELECTRICAL CHARACTERISTICS — Dual Supplies. MIN. TYP. MAX
Precision, CMOS Analog Switches ABSOLUTE MAXIMUM RATINGS Note 1: ELECTRICAL CHARACTERISTICS — Dual Supplies MIN TYP MAX
Voltage Referenced to V- Continuous Power Dissipation (TA = +70°C) (Note 1) V+..+44V Plastic DIP (derate 9.09mW/°C above +70°C)..727mW GND ..+25V SO (derate 5.88mW/°C above +70°C) ..471mW VL ...(GND - 0.3V) to (V+ + 0.3V) CERDIP (derate 8.00mW/°C above +70°C) ..640mW IN, COM, NC, NO..(V- - 2V) to (V+ + 2V) or 30mA, Operating Temperature Ranges: whichever occurs first MAX31_C_ _...0°C to +70°C Continuous Current (any terminal) ...30mA MAX31_E_ _ ..-40°C to +85°C Peak Current, NC, NO, COM MAX31_MJA..-55°C to +125°C (pulsed at 1ms, 10% duty cycle max)..100mA Storage Temperature Range ..-55°C to +150°C ESD ...±2000V Lead Temperature (soldering, 10sec) ..+300°C
Note 1:
All leads are soldered or welded to PC board. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(V+ = 15V, V- = -15V, VL = 5V, GND = 0V, VINL = 0.8V, VINH = 2.4V, TA = TMIN to TMAX, unless otherwise noted.)
MIN TYP MAX PARAMETER SYMBOL CONDITIONS TEMP. UNITS (Note 2)
V Analog-Signal Range COM, (Note 3) -15 15 V
MAX317/MAX318/MAX319
VNO, VNC V C, E COM = ±12.5V, 20 35 TA = +25°C On Resistance R M ON I(NC or NO) = -10mA, 30 Ω V+ = 13.5V, V- = -13.5V TA = TMIN to TMAX 45 I On Resistance Match (NC OR NO) = -10mA, T R A = +25°C 2 V Ω ON Between Channels (Note 4) COM = 10V or -10V, T V+ = 15V, V- = -15V A = TMIN to TMAX 3 I On Resistance Flatness (NC OR NO) = -10mA, T R A = +25°C 3 V Ω ON (Note 4) COM = 5V or -5V, T V+ = 15V, V- = -15V A = TMIN to TMAX 5 INC(OFF) V+ = 16.5V, V- = -16.5V, TA = +25°C -0.25 0.25 NO or NC Off Leakage Current or VCOM = ±15.5V, C, E -6 6 nA INO(OFF) VNC or VNO = ±15.5V M -20 20 TA = +25°C -0.25 -0.1 0.25 MAX317, C, E -6 6 V+ = 16.5V, MAX318 M -20 20 V- = -16.5V, COM Off Leakage Current ICOM(OFF) nA VCOM = ±15.5V, TA = +25°C -0.75 -0.1 0.75 VNC or VNO = –+15.5V MAX319 C, E -10 10 M -60 60 TA = +25°C -0.4 0.4 MAX317, C, E -10 10 MAX318 V+ = 16.5V, M -40 40 COM On Leakage Current ICOM V- = -16.5V, (ON) nA VNC or VNO = VD = TA = +25°C -0.75 0.75 ±15.5V MAX319 C, E -10 10 M -60 60
2 ________________________________________________________________________________________________
