Datasheet ADA4001-2 (Analog Devices) - 6 Manufacturer Analog Devices Description Low Noise, Low Input Bias Current, Rail-to-Rail Output, JFET Dual Op Amp Pages / Page 12 / 6 — ADA4001-2. Data Sheet. SY = ±15V. A = 25°C. 100. (V). (Ω). AV = +100. – … Revision C File Format / Size PDF / 327 Kb Document Language English
ADA4001-2. Data Sheet. SY = ±15V. A = 25°C. 100. (V). (Ω). AV = +100. – V. UT O. AV = +10. 0.1. AV = +1. 0.01. 10k. 100k. IOUT SINK (mA). FREQUENCY (kHz)
Model Line for this Datasheet Text Version of Document ADA4001-2 Data Sheet 1k ADA4001-2 ADA4001-2 V V SY = ±15V SY = ±15V 10 T T A = 25°C A = 25°C 100 (V) 1 10 SS (Ω) AV = +100 – V UT O UT Z O 1 V AV = +10 0.1 0.1 AV = +1 0.01 0.01 0.01 0.1 1 10 100 0090.1 1 10 100 1k 10k 100k 014IOUT SINK (mA) 10375-FREQUENCY (kHz) 10375- Figure 8. Dropout Voltage vs. Sink Current Figure 11. Closed-Loop Output Impedance vs. Frequency120 270 120 ADA4001-2 ADA4001-2 VSY = ±15V VSY = ±15V 100 T 225 A = 25°C 100 TA = 25°C RL = 2kΩ 80 180 80 60 135 PSRR– B) rees) B) 60 d d 40 90 Deg N ( ( AI E RR ( S G 40 P 20 45 HAS PSRR+ P 20 0 0 –20 –45 0 –40 –90 –20 0.01 0.1 1 10 100 1k 10k 100k 0120.1 1 10 100 1k 10k 015FREQUENCY (kHz) 10375-FREQUENCY (kHz) 10375- Figure 9. Open-Loop Gain and Phase vs. Frequency Figure 12. PSRR vs. Frequency50 140 ADA4001-2 ADA4001-2 AV = +100 VSY = ±15V VSY = ±15V TA = 25°C 120 TA = 25°C RL = 2kΩ 30 100 AV = +10 B) B) 80 d d 10 N ( RR ( AI G AV = +1 60 CM 40 –10 20 –30 0 1 10 100 1k 10k 100k 0130.1 1 10 100 1k 10k 016FREQUENCY (kHz) FREQUENCY (kHz) 10375- 10375- Figure 10. Closed-Loop Gain vs. Frequency Figure 13. CMRR vs. Frequency Rev. C | Page 6 of 12 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Total Noise Including Source Resistors I-V Conversion Applications Photodiode Circuits Input Bias Current Noise Considerations Outline Dimensions Ordering Guide
