Datasheet AD8392A (Analog Devices) - 10
DescriptionLow Power, High Output Current, Quad Op Amp, Dual-Channel ADSL/ADSL2+ Line Driver
Pages / Page12 / 10 — AD8392A. Data Sheet. MULTITONE POWER RATIO. –10. –20. –30. –40. Bm). –50. …
File Format / SizePDF / 504 Kb
AD8392A. Data Sheet. MULTITONE POWER RATIO. –10. –20. –30. –40. Bm). –50. –60. –70. –80. –90. –100. CENTER 1.9664kHz. SPAN 10kHz. CENTER 646.9kHz
AD8392A Data Sheet MULTITONE POWER RATIO –10 –20 –30 –40 Bm) –50 –60 –70 –80 –90 –100 CENTER 1.9664kHz SPAN 10kHz CENTER 646.9kHz
link to page 10 link to page 10
AD8392A Data Sheet MULTITONE POWER RATIO 0
The DMT signal used in ADSL/ADSL2+ systems carries data in
–10
discrete tones or bins, which appear in the frequency domain in
–20
evenly spaced 4.3125 kHz intervals. In applications using this
–30
type of waveform, multitone power ratio (MTPR) is a commonly
–40
used measure of linearity. MTPR is defined as the measured
Bm) –50
difference from the peak of one tone that is loaded with data to
(d –60
the peak of an adjacent tone that is intentional y left empty. Figure 19 and Figure 20 show the AD8392A MTPR for a 5.5
–70
crest factor waveform for empty bins in the ADSL and extended
–80
ADSL2+ bandwidths.
–90
044
06477-
0
Figure 20. MTPR at 1.966 MHz
–10 –20 –30 –40 Bm) –50 (d –60 –70 –80 –90
043
–100 CENTER 646.9kHz SPAN 10kHz
06477- Figure 19. MTPR at 647 kHz Rev. A | Page 10 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS SUPPLIES, GROUNDING, AND LAYOUT POWER MANAGEMENT THERMAL CONSIDERATIONS TYPICAL ADSL/ADSL2+ APPLICATION MULTITONE POWER RATIO OUTLINE DIMENSIONS ORDERING GUIDE NOTES
