Datasheet ADA4899-1 (Analog Devices) - 10 Manufacturer Analog Devices Description Unity-Gain Stable, Ultralow Distortion, 1 nV/√Hz Voltage Noise, High Speed Op Amp Pages / Page 20 / 10 — ADA4899-1. Data Sheet. 1.5. 0.3. 10 G = +1. VS = ±5V. DISABLE = NC. 1.0. … Revision C File Format / Size PDF / 611 Kb Document Language English
ADA4899-1. Data Sheet. 1.5. 0.3. 10 G = +1. VS = ±5V. DISABLE = NC. 1.0. 0.2. 0.5. 0.1. INPUT. N LI. E (. ERROR. ANCE. E P 0.1. T L. OUTPUT. T S. –0.5. –0.1
Model Line for this Datasheet Text Version of Document ADA4899-1 Data Sheet 1.5 0.3 10 G = +1 VS = ±5V DISABLE = NC 1.0 0.2 ) ) 1 % 0.5 0.1 ( (Ω G V) INPUT N LI E ( ERROR ANCE G TT D A 0 0 E E P 0.1 T L OUTPUT M T S I U VO UT TP –0.5 –0.1 P U T O U O 0.01 –1.0 –0.2 G = +1 5V 5 02S = ±5V 0- -01R 72L = 1kΩ 20 05–1.5 –0.3 0570.001 0 25 50 75 100 125 150 0.001 0.01 0.1 1 10 100 1000 TIME (ns) FREQUENCY (MHz) Figure 29. Settling Time, G = +1 Figure 32. Output Impedance vs. Frequency1.5 0.3 100k G = +1 VS = ±5V DISABLE = –5V 1.0 0.2 INPUT ) ) 10k % 0.5 0.1 ( (Ω ) G N (V LI E ANCE G TT D A 0 0 E E P 1k T S L M T OUTPUT I U VO ERROR P UT T –0.5 –0.1 P U T O U O 100 –1.0 –0.2 G = +5 6V 4S = ±5V -02 -01 20RL = 1kΩ 20 057–1.5 –0.3 05710 0 25 50 75 100 125 150 0.1 1 10 100 1000 TIME (ns) FREQUENCY (MHz) Figure 30. Settling Time, G = +5 Figure 33. Output Impedance vs. Frequency (Disabled)100k –20 G = +1 G = +1 VS = ±5V –30 RL = 1kΩ DISABLE = NC RF = 1kΩ –40 B) d 10k ) –50 N ( Ω ( IO –60 CT NCE JE –70 DA E 1k RE –80 P E M D I O –90 T U -M N –100 INP O 100 M –110 V M S = +5V CO –120 6 0 -01V -02–130 S = ±5V 20 20 05710 057–140 0.1 1 10 100 1000 10 100 1k 10k 100k 1M 10M 100M 1G FREQUENCY (MHz) FREQUENCY (Hz) Figure 31. Input Impedance vs. Frequency Figure 34. Common-Mode Rejection vs. Frequency Rev. C | Page 10 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION PACKAGING INNOVATION DISABLE\ PIN APPLICATIONS INFORMATION UNITY-GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE ADC DRIVER DISABLE\ PIN OPERATION ADA4899-1 MUX CIRCUIT CONSIDERATIONS PCB Layout Power Supply Bypassing Grounding OUTLINE DIMENSIONS ORDERING GUIDE
