Datasheet AD8003 (Analog Devices) - 10
DescriptionTriple, 1.5 GHz Op Amp
Pages / Page16 / 10 — AD8003. Data Sheet. VS = ±5V VS = +5V. VS = ±5V. VS = +5V. (µA. OSV. I B. …
RevisionC
File Format / SizePDF / 744 Kb
AD8003. Data Sheet. VS = ±5V VS = +5V. VS = ±5V. VS = +5V. (µA. OSV. I B. –20. –10. –40. –15. –60. VCM (V). G = +2. VDIS (VS = ±5V). RL = 150Ω
AD8003 Data Sheet VS = ±5V VS = +5V VS = ±5V VS = +5V (µA OSV I B –20 –10 –40 –15 –60 VCM (V) G = +2 VDIS (VS = ±5V) RL = 150Ω
AD8003 Data Sheet 80 20 60 15 VS = ±5V VS = +5V 10 VS = ±5V VS = +5V 40 5 V) 20 ) (m 0 (µA OSV 0 I B –5 –20 –10 –40
31
–15
2 0 03 1- 1- 72 72 05
–60
05
–20 –5 –4 –3 –2 –1 0 1 2 3 4 5 –5 –4 –3 –2 –1 0 1 2 3 4 5 VCM (V) VCM (V)
Figure 28. Offset Voltage vs. Input Common-Mode Range Figure 31. Noninverting Input Bias Current vs. Common-Mode Range
10 6 8 VS = +5V G = +2 VDIS (VS = ±5V) RL = 150Ω V 6 IN = 0.5V dc 5 V 4 S = ±5V 2 ) 4 V (
A) 0 E ( I B UD 3 VDIS (VS = +5V) –2 IT L P –4 AM 2 VOUT (VS = +5V) V –6 OUT (VS = ±5V) VOUT (VS = +5V)
3
–8 1
03 1- 14 72
V
0
OUT (VS = ±5V)
05
–10
1-
572 0
0 V 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 OUT (V) TIME (µs)
Figure 29. Inverting Input Bias Current Linearity Figure 32. Disable Switching Time for Various Supplies
10 200 G = +2 10 40 G = +2 RL = 150Ω R 9 L = 150Ω V 150 9 30 S = ±5V V ) ) S = 5V ) A ) 8 A A A m 100 8 20 ( m T T ( T T 7 50 N N EN 7 10 EN R I R I DIS CC R RRE 6 R RRE U 0 IDIS 6 U 0 Y C 5 –50 IN CU Y C 5 –10 IN CU PPL N P PPL N P U 4 –100 W U 4 –20 W IVE S 3 –150 R DO IVE S 3 –30 R DO T E T E SI W 2 I SI W CC –200 O 2 –40 O PO P PO P 1 –250 1 –50
8
0 –300
9
0 –60
02
02 1-
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0
1- 72
POWER DOWN PIN VOLTAGE (VDIS (V))
72
05
DIS (V))
05 Figure 30. POWER DOWN Pin Current and Supply Current vs. Figure 33. POWER DOWN Pin Current and Supply Current vs. POWER DOWN Pin Voltage POWER DOWN Pin Voltage Rev. C | Page 10 of 16 Document Outline Features Applications Connection Diagram General Description Table of Contents Revision History Specifications with ±5 V Supply Specifications with +5 V Supply Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Typical Performance Characteristics Applications Information Gain Configurations RGB Video Driver Printed Circuit Board Layout Low Distortion Pinout Signal Routing Exposed Paddle Power Supply Bypassing Grounding Outline Dimensions Ordering Guide
