Datasheet AD8651, AD8652 (Analog Devices) - 9 Manufacturer Analog Devices Description 50 MHz, Precision Low Distortion, Low Noise CMOS Dual Op Amp Pages / Page 20 / 9 — Data Sheet. AD8651/AD8652. 140. S = ±2.5V. 120. L = 1MΩ. CL = 47pF. 100. … Revision D File Format / Size PDF / 468 Kb Document Language English
Data Sheet. AD8651/AD8652. 140. S = ±2.5V. 120. L = 1MΩ. CL = 47pF. 100. –45. G = 100. B d. rees). G = 10. –90. D (. O O. G = 1. HAS P. S O. –135. L C. –20. –180
Model Line for this Datasheet Text Version of Document Data Sheet AD8651/AD8652 140 0 60 V V S = ±2.5V S = ±2.5V R 120 L = 1MΩ CL = 47pF 40 100 –45 G = 100 ) ) B B d (d ( 80 IN IN 20 rees) A G = 10 G GA eg P P 60 –90 D ( O O OO E -L -L 0 40 D N E G = 1 E HAS P S O OP 20 –135 L C –20 0 –20 –180 3–40 10 100 1k 10k 100k 1M 10M 100M 26 025k 50k 500k 5M 50M 300M -0 1- 01FREQUENCY (Hz) 30FREQUENCY (Hz) 33 03 0 Figure 23. Open-Loop Gain and Phase vs. Frequency Figure 26. Closed-Loop Gain vs. Frequency117 6 VS = ±2.5V RL = 1kΩ 5 116 ) V V S = 5V ) ( B G d IN 4 ( IN 115 SW T GA P 3 TPU OO U 114 -L VS = 2.7V N M O E 2 P O IMU X 113 MA 1 112 40 –50 0 50 100 150 27 02100k 1M 10M 100M -0 1- 01TEMPERATURE (°C) 30FREQUENCY (Hz) 33 03 0 Figure 24. Open-Loop Gain vs. Temperature Figure 27. Maximum Output Swing vs. Frequency140 V V S = ±2.5V S = ±2.5V C 130 I L = 47pF L = 250µA AV = 1 IL = 2.5mA 120 ) B I (d L = 4.2mA ) 110 IN IV A D G 1V/ 100 ( E OOP G -L TA N 90 E VOL OP 80 70 60 280 50 100 150 200 250 25 0 -0 1- 01OUTPUT VOLTAGE SWING FROM THE RAILS (mV) 30TIME (100µs/DIV) 33 03 0 Figure 25. Open-Loop Gain vs. Output Voltage Swing Figure 28. Large Signal Response Rev. D | Page 9 of 20 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Thermal Resistance Typical Performance Characteristics Applications Theory of Operation Rail-to-Rail Output Stage Rail-to-Rail Input Stage Input Protection Overdrive Recovery Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Settling Time THD Readings vs. Common-Mode Voltage Driving a 16-Bit ADC Outline Dimensions Ordering Guide
