Datasheet AD8510, AD8512, AD8513 (Analog Devices) - 10
Description | Precision, Very Low Noise, Low Input Bias Current, Wide Bandwidth JFET Quad Operational Amplifier |
Pages / Page | 21 / 10 — AD8510/AD8512/AD8513. Date Sheet. 300. VSY = ±15V. VSY = ±15V, ±5V. 270. … |
Revision | K |
File Format / Size | PDF / 383 Kb |
AD8510/AD8512/AD8513. Date Sheet. 300. VSY = ±15V. VSY = ±15V, ±5V. 270. VIN = 50mV. 240. B) d. (Ω 210. N (. AV = 100. 180. G P. PEDANCE 150. AV = 1
AD8510/AD8512/AD8513 Date Sheet 70 300 VSY = ±15V 60 VSY = ±15V, ±5V 270 VIN = 50mV 50 240 ) B) d 40 (Ω 210 N ( AV = 100 AI 30 180 G P 20 PEDANCE 150 AV = 1 A -LOO V = 10 IM 120 D 10 E PUT 90 AV = 100 LOS 0 UT C O AV = 1 60 –10 AV = 10 30 –20
019 022 02729- 02729-
–30 0 1k 10k 100k 1M 10M 50M 100 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 19. Closed-Loop Gain vs. Frequency Figure 22. Output Impedance vs. Frequency
120 1k VSY = ±5V TO ±15V VSY = ±15V 100 z) H V/ 80 Y (n 100 T SI B) d EN 60 RR ( ISE D CM O 40 E N 10 G A T L 20 VO
020 023
0
02729-
1
02729-
100 1k 10k 100k 1M 10M 100M 1 10 100 1k 10k FREQUENCY (Hz) FREQUENCY (Hz)
Figure 20. CMRR vs. Frequency Figure 23. Voltage Noise Density vs. Frequency
120 V V SY = ±15V SY = ±5V, ±15V 100 80 IV) –PSRR D V/ B) µ 60 d E (1 G RR ( S A P 40 LT +PSRR VO 20 0
024 021 02729-
–20
02729-
100 1k 10k 100k 1M 10M 100M TIME (1s/DIV) FREQUENCY (Hz)
Figure 21. PSRR vs. Frequency Figure 24. 0.1 Hz to 10 Hz Input Voltage Noise Rev. K | Page 10 of 21 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS GENERAL APPLICATION INFORMATION INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL TOTAL HARMONIC DISTORTION (THD) + NOISE TOTAL NOISE INCLUDING SOURCE RESISTORS SETTLING TIME OVERLOAD RECOVERY TIME CAPACITIVE LOAD DRIVE OPEN-LOOP GAIN AND PHASE RESPONSE PRECISION RECTIFIERS I-V CONVERSION APPLICATIONS Photodiode Circuits Signal Transmission Applications Crosstalk OUTLINE DIMENSIONS ORDERING GUIDE
