Datasheet AD8065, AD8066 (Analog Devices) - 8
DescriptionHigh Performance, 145 MHzFastFET Op Amp
Pages / Page28 / 8 — AD8065/AD8066. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit
RevisionL
File Format / SizePDF / 969 Kb
AD8065/AD8066 Data Sheet Parameter Conditions Min Typ Max Unit
POWER SUPPLY Operating Range 5 24 V AD8065WARTZ only: TMIN − TMAX 5 10 V Quiescent Current per Amplifier 5.8 6.4 7.0 mA AD8065WARTZ only: TMIN − TMAX 7.0 mA Power Supply Rejection Ratio ±PSRR −78 −100 dB AD8065WARTZ only: TMIN − TMAX −78 dB Rev. L | Page 8 of 28 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications ±5 V Specifications ±12 V Specifications +5 V Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Test Circuits SOIC-8 Pinout Theory of Operation Closed-Loop Frequency Response Noninverting Closed-Loop Frequency Response Inverting Closed-Loop Frequency Response Wideband Operation Input Protection Thermal Considerations Input and Output Overload Behavior Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Input-to-Output Coupling Wideband Photodiode Preamp High Speed JFET Input Instrumentation Amplifier Video Buffer Outline Dimensions Ordering Guide Automotive Products
