Datasheet AD8022 (Analog Devices) - 8
Description | Dual High Speed, Low Noise Op Amp |
Pages / Page | 16 / 8 — AD8022. Data Sheet. 0.4. –50. 0.3. –60. 0.2. –70. 0.1. +0.1%. –80. RROR … |
Revision | C |
File Format / Size | PDF / 301 Kb |
AD8022. Data Sheet. 0.4. –50. 0.3. –60. 0.2. –70. 0.1. +0.1%. –80. RROR (%. –90. –0.1%. –100. TTLING E. –0.1. E S. 3RD. –0.2. –110. HARMONIC DISTORTION (dB). 2ND
AD8022 Data Sheet 0.4 –50 0.3 –60 0.2 –70 ) 0.1 +0.1% –80 RROR (% 0 –90 –0.1% –100 TTLING E –0.1 E S 3RD –0.2 –110 HARMONIC DISTORTION (dB) 2ND –0.3 –120 –0.4
01053-016
–130
01053-019
0 20 40 60 80 100 120 1k 10k 100k 1M 10M TIME (ns) FREQUENCY (Hz)
Figure 16. Settling Time to 0.1%, VS = ±12 V, Figure 19. Distortion vs. Frequency, VS = ±12 V, RL = 500 Ω, Step Size = 2 V p-p, G = +2, RL = 500 Ω RF = 0 Ω, VOUT = 2 V p-p, G = +1
0.4 –50 0.3 –60 0.2 –70 ) 2ND 0.1 +0.1% –80 RROR (% 3RD 0 –90 –0.1 –0.1% –100 TTLING E E S –0.2 –110 HARMONIC DISTORTION (dB) –0.3 –120 –0.4
01053-017
–130
01053-020
Figure 17. Settling Time to 0.1%, VS = ±2.5 V, Step Size = 2 V p-p, Figure 20. Distortion vs. Frequency, VS = ±2.5 V, G = +2, RL = 500 Ω RL = 500 Ω, RF = 0 Ω, VOUT = 2 V p-p, G = +1
70 –20 –30 60 NEGATIVE EDGE –40 50 POSITIVE EDGE –50 /
μ
s) V 40 E ( –60 3RD 30 –70 EW RAT SL –80 20 2ND HARMONIC DISTORTION (dBc) –90 10 –100 0
01053-018
–120
01053-021
2.5 4.5 6.5 8.5 10.5 12.5 0 5 10 15 20 SUPPLY VOLTAGE (V) OUTPUT VOLTAGE (V p-p)
Figure 18. Slew Rate vs. Supply Voltage, G = +2 Figure 21. Distortion vs. Output Voltage, VS = ±12 V, G = +2, f = 1 MHz, RL = 500 Ω, RF = 715 Ω Rev. C | Page 8 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTIONS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS DMT MODULATION AND MULTITONE POWER RATIO (MTPR) CHANNEL CAPACITY AND SNR POWER SUPPLY AND DECOUPLING LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
