Datasheet AD8017 (Analog Devices) - 7
Description | Low Cost, High Output Current, High Output Voltage Line Driver |
Pages / Page | 16 / 7 — AD8017. –20. –40. –60. dBc. – –60. –80. 2ND. DISTORTION –100. DISTORTION. … |
Revision | C |
File Format / Size | PDF / 235 Kb |
AD8017. –20. –40. –60. dBc. – –60. –80. 2ND. DISTORTION –100. DISTORTION. 3RD. –100. –120. –140. 100. 1000. LOAD RESISTANCE –. VS =. 2.5V. –10. f = 1MHz. G = +2
AD8017 –20 0 –20 –40 –40 –60 dBc dBc – – –60 –80 2ND –80 2ND DISTORTION –100 DISTORTION 3RD –100 3RD –120 –120 –140 –140 0 10 100 1000 0 10 100 1000 LOAD RESISTANCE –
LOAD RESISTANCE –
⍀ TPC 11. Distortion vs. RL, VS = ±6 V, G = +2, TPC 14. Distortion vs. RL, VS = ±2.5 V, G = +2, VOUT = 2 V p-p, f = 1 MHz VOUT = 2 V p-p, f = 1 MHz
0 0 VS =
ⴞ
6V VS =
ⴞ
2.5V –10 f = 1MHz –10 f = 1MHz dBc dBc – G = +2 – G = +2 –20 –20 –30 –30 –40 –40 –50 –50 R R L = 25
L = 25
–60 –60 RL = 100
–70 HIGHEST HARMONIC DISTORTION –70 R HIGHEST HARMONIC DISTORTION L = 100
–80 –80 0 1 2 3 4 5 6 0 0.5 1.0 1.5 2.0 2.5 OUTPUT VOLTAGE – Volts OUTPUT VOLTAGE – Volts
TPC 12. Distortion vs. Output Voltage, VS = ±6 V, TPC 15. Distortion vs. Output Voltage, VS = ±2.5 V, G = +2, f = 1 MHz G = +2, f = 1 MHz
0 0 VS =
ⴞ
6V VS =
ⴞ
2.5V –10 f = 10MHz –10 f = 10MHz dBc dBc – G = +2 – G = +2 –20 –20 –30 –30 RL = 25
–40 –40 RL = 25
–50 –50 –60 RL = 100
–60 RL = 100
–70 HIGHEST HARMONIC DISTORTION HIGHEST HARMONIC DISTORTION –70 –80 0 1 2 3 4 5 6 0 0.5 1 1.5 2 2.5 OUTPUT VOLTAGE – Volts OUTPUT VOLTAGE – Volts
TPC 13. Distortion vs. Output Voltage, VS = ±6 V, TPC 16. Distortion vs. Output Voltage, VS = ±2.5 V, G = +2, f = 10 MHz G = +2, f = 10 MHz REV. C –7–
