Datasheet AD8010 (Analog Devices) - 3
DescriptionLow Power, High Current Distribution Amplifier
Pages / Page12 / 3 — AD8010. ABSOLUTE MAXIMUM RATINGS1. MAXIMUM POWER DISSIPATION. 3.0. TJ = …
RevisionB
File Format / SizePDF / 192 Kb
AD8010. ABSOLUTE MAXIMUM RATINGS1. MAXIMUM POWER DISSIPATION. 3.0. TJ = 150. 2.5. Watts –. 8-LEAD MINI-DIP PACKAGE. 2.0
AD8010 ABSOLUTE MAXIMUM RATINGS1 MAXIMUM POWER DISSIPATION 3.0 TJ = 150 2.5 Watts – 8-LEAD MINI-DIP PACKAGE 2.0
Supply Voltage . 12.6 V The maximum power that can be safely dissipated by the Internal Power Dissipation2 AD8010 is limited by the associated rise in junction temperature. Plastic Package (N) . Observe Power Derating Curves The maximum safe junction temperature for plastic encapsu- Small Outline Package (R) . Observe Power Derating Curves lated devices is determined by the glass transition temperature Wide Body SOIC (R-16) . Observe Power Derating Curves of the plastic, approximately +150°C. Temporarily exceeding Input Voltage (Common-Mode) . ± VS this limit may cause a shift in parametric performance due to a Differential Input Voltage . ± 1.2 V change in the stresses exerted on the die by the package. Exceed- Output Short Circuit Duration ing a junction temperature of +175°C for an extended period . Observe Power Derating Curves can result in device failure. Storage Temperature Range N, R . –65°C to +125°C While the AD8010 is internally short circuit protected, this Operating Temperature Range (A Grade) . –40°C to +85°C may not be sufficient to guarantee that the maximum junction Lead Temperature Range (Soldering 10 sec) . 300°C temperature (+150°C) is not exceeded under all conditions. To NOTES ensure proper operation, it is necessary to observe the maximum 1Stresses above those listed under Absolute Maximum Ratings may cause perma- power derating curves. nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2Specification is for device in free air: 8-Lead Plastic Package: θJA = 90°C/W 8-Lead SOIC Package: θJA = 122°C/W 16-Lead SOIC Package: θJA = 73°C/W
3.0 TJ = 150 C 2.5 Watts – 8-LEAD MINI-DIP PACKAGE 2.0 16-LEAD SOIC PACKAGE (WIDEBODY) 1.5 1.0 8-LEAD SOIC PACKAGE 0.5 MAXIMUM POWER DISSIPATION 0 –50 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 AMBIENT TEMPERATURE – C
Figure 2. Plot of Maximum Power Dissipation vs. Temperature
ORDERING GUIDE Model Temperature Range Package Description Package Options
AD8010AN –40°C to +85°C 8-Lead Plastic DIP N-8 AD8010AR –40°C to +85°C 8-Lead Plastic SOIC SO-8 AD8010AR-16 –40°C to +85°C 16-Lead Wide Body SOIC R-16 AD8010AR-REEL REEL SOIC 13" REEL AD8010AR-REEL7 REEL SOIC 7" REEL AD8010AR-16-REEL REEL SOIC 13" REEL AD8010AR-16-REEL7 REEL SOIC 7" REEL
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily
WARNING!
accumulate on the human body and test equipment and can discharge without detection. Although the AD8010 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD
ESD SENSITIVE DEVICE
precautions are recommended to avoid performance degradation or loss of functionality. REV. B –3–
