Datasheet AD813 (Analog Devices) - 3
DescriptionSingle Supply, Low Power Triple Video Amplifier
Pages / Page19 / 3 — AD813. Model. AD813A. Conditions. Min. Typ. Max. Units
RevisionB
File Format / SizePDF / 563 Kb
AD813 Model AD813A Conditions Min Typ Max Units
AD813 Model AD813A Conditions V Min Typ Max Units S
OUTPUT CHARACTERISTICS Output Voltage Swing R = 150 Ω, T –T ±5 V 3.5 3.8 ±V L MIN MAX R = 1 kΩ, T –T ±15 V 13.6 14.0 ±V L MIN MAX Output Current ±5 V 25 40 mA ±15 V 30 50 mA Short Circuit Current G = +2, R = 715 Ω ±15 V 100 mA F V = 2 V IN MATCHING CHARACTERISTICS Dynamic Crosstalk G = +2, f = 5 MHz ±5 V, ± 15 V –65 dB Gain Flatness Match G = +2, f = 40 MHz ±15 V 0.1 dB DC Input Offset Voltage T –T ±5 V, ± 15 V 0.5 3.5 mV MIN MAX –Input Bias Current T –T ±5 V, ± 15 V 2 25 µA MIN MAX POWER SUPPLY Operating Range ±1.2 ±18 V Quiescent Current Per Amplifier ±5 V 3.5 4.0 mA ±15 V 4.5 5.5 mA T –T ±15 V 6.7 mA MIN MAX Quiescent Current, Powered Down Per Amplifier ±5 V 0.5 0.65 mA ±15 V 0.75 1.0 mA Power Supply Rejection Ratio Input Offset Voltage V = ± 1.5 V to ± 15 V 72 80 dB S –Input Current 0.3 0.8 µA/V +Input Current 0.005 0.05 µA/V DISABLE CHARACTERISTICS Off Isolation f = 5 MHz ±5 V, ± 15 V –57 dB Off Output Impedance G = +1 ±5 V, ± 15 V 12.5 pF Channel-to-Channel 2 or 3 Channels ±5 V, ± 15 V –65 dB Isolation Mux, f = 5 MHz Turn-On Time ±5 V, ± 15 V 100 ns Turn-Off Time 80 ns NOTES 1Slew rate measurement is based on 10% to 90% rise time in the specified closed-loop gain. Specifications subject to change without notice. REV. B –3–
