Datasheet SSM2135 (Analog Devices) - 7 Manufacturer Analog Devices Description Dual Single-Supply Audio Operational Amplifier Pages / Page 16 / 7 — SSM2135. VS = 5V. 40 TA = 25°C. TA = 25°C. V = +100. L = 10kΩ. ) B. B) d. … Revision G File Format / Size PDF / 305 Kb Document Language English
SSM2135. VS = 5V. 40 TA = 25°C. TA = 25°C. V = +100. L = 10kΩ. ) B. B) d. –20. AV = +10. K (. –40. T S. –60. D E. CRO. –80. V = +1. –100. –105. –10. –120. –140. 100
Model Line for this Datasheet Text Version of Document SSM2135 60 50 VS = 5V VS = 5V 40 TA = 25°C TA = 25°C A R V = +100 L = 10kΩ 40 20 ) B 0 d 30 ( B) d IN –20 AV = +10 K ( GA 20 P AL –40 T S OO S -L 10 –60 D E CRO A –80 OS V = +1 L 0 C –100 –105 –10 –120 –140 –20 10 100 1k 10k 100k 1M 10M 15 18 01k 10k 100k 1M 10M 0 9- 9-FREQUENCY (Hz) 34FREQUENCY (Hz) 34 00 00 Figure 15. Crosstalk vs. Frequency Figure 18. Closed-Loop Gain vs. Frequency140 100 VS = 5V VS = 5V TA = 25°C TA = 25°C 120 ) B 80 0 d ( 100 ) ION B T d 60 45 C ( IN GAIN es) JE 80 re E GA eg R D E 40 90 ( PHASE 60 E OD OOP -L -M N HAS E 20 135 P ON P 40 M O OM C 20 0 180 0 –20 225 100 1k 10k 100k 1M 16 01k 10k 100k 1M 10M 19 0 9- 9-FREQUENCY (Hz) 34FREQUENCY (Hz) 34 00 00 Figure 16. Common-Mode Rejection vs. Frequency Figure 19. Open-Loop Gain and Phase vs. Frequency140 50 VS = 5V VS = 5V AV = +1 R 120 45 L= 2kΩ TA = 25°C VIN = 100mV p-p 40 TA = 25°C 100 AV = +1 35 ) 80 % ( B) 30 T d +PSRR O NEGATIVE EDGE R ( 60 O 25 R S SH –PSRR P 40 20 VER O POSITIVE EDGE 15 20 10 0 5 –20 0 010 100 1k 10k 100k 1M 17 00 100 200 300 400 500 02 9- 9-FREQUENCY (Hz) 34LOAD CAPACITANCE (pF) 34 00 00 Figure 17. Power Supply Rejection Ratio vs. Frequency Figure 20. Small Signal Overshoot vs. Load Capacitance Rev. G | Page 7 of 16 Document Outline FEATURES APPLICATIONS PIN CONNECTIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION APPLICATION CIRCUITS Low Noise Stereo Headphone Driver Amplifier Low Noise Microphone Preamplifier Single Supply Differential Line Driver Single-Supply Differential Line Receiver Pseudoreference Voltage Generator Digital Volume Control Circuit Logarithmic Volume Control Circuit OUTLINE DIMENSIONS ORDERING GUIDE
