Datasheet AD818 (Analog Devices) - 3
DescriptionLow Cost, Low Power Video Op Amp
Pages / Page15 / 3 — AD818. AD818A. Parameter. Conditions. Min. Typ. Max. Unit
RevisionD
File Format / SizePDF / 571 Kb
AD818 AD818A Parameter Conditions Min Typ Max Unit
AD818 AD818A Parameter Conditions VS Min Typ Max Unit
POWER SUPPLY REJECTION VS = ± 5 V to ± 15 V 80 90 dB TMIN to TMAX 80 dB INPUT VOLTAGE NOISE f = 10 kHz ±5 V, ±15 V 10 nV/÷Hz INPUT CURRENT NOISE f = 10 kHz ±5 V, ±15 V 1.5 pA/÷Hz INPUT COMMON-MODE VOLTAGE RANGE ±5 V +3.8 +4.3 V –2.7 –3.4 V ±15 V +13 +14.3 V –12 –13.4 V 0 V, +5 V +3.8 +4.3 V +1.2 +0.9 V OUTPUT VOLTAGE SWING RLOAD = 500 W ±5 V 3.3 3.8 ±V RLOAD = 150 W ±5 V 3.2 3.6 ±V RLOAD = 1 kW ±15 V 13.3 13.7 ±V RLOAD = 500 W ±15 V 12.8 13.4 ±V RLOAD = 500 W 0 V, +5 V 1.5, 3.5 V Output Current ±15 V 50 mA ±5 V 50 mA 0 V, +5 V 30 mA Short-Circuit Current ±15 V 90 mA INPUT RESISTANCE 300 kW INPUT CAPACITANCE 1.5 pF OUTPUT RESISTANCE Open Loop 8 W POWER SUPPLY Operating Range Dual Supply ±2.5 ±18 V Single Supply +5 +36 V Quiescent Current ±5 V 7.0 7.5 mA T ± MIN to TMAX 5 V 7.5 mA ±15 V 7.5 mA T ± MIN to TMAX 15 V 7.0 7.5 mA *Full power bandwidth = slew rate/(2p VPEAK). Specifications subject to change without notice. REV. D –3– Document Outline Untitled
