Datasheet AD818 (Analog Devices) - 8
Description | Low Cost, Low Power Video Op Amp |
Pages / Page | 15 / 8 — AD818. 0.02. DIFF GAIN. 0.01. +VS. 3.3. 0.06. 0.00. VIN. 0.05. PULSE … |
Revision | D |
File Format / Size | PDF / 571 Kb |
AD818. 0.02. DIFF GAIN. 0.01. +VS. 3.3. 0.06. 0.00. VIN. 0.05. PULSE (LS). OR FUNCTION. TEKTRONIX. DIFF PHASE. (SS). GENERATOR. P6201 FET. 7A24. PROBE
AD818 CF 0.02 1k
DIFF GAIN 0.01 +VS 3.3
F 0.06 0.00 0.01
F HP VIN 0.05 PULSE (LS) 1k
OR FUNCTION TEKTRONIX TEKTRONIX DIFF PHASE (SS) AD818 GENERATOR P6201 FET 7A24 50
V PROBE PREAMP 0.04 OUT DIFFERENTIAL GAIN (%) DIFFERENTIAL PHASE (Degrees) 0.01
F 0.03 RL 5 10 15 3.3
F SUPPLY VOLTAGE (
ⴞ
V) –VS
TPC 19. Differential Gain and Phase vs. Supply Voltage TPC 22. Inverting Amplifier Connection
C 0.1dB C 10 VS CC FLATNESS 2V 50ns 1k 1k
9
ⴞ
15V 2pF 55MHz
ⴞ
V 5V 1pF 43MHz OUT 100 +5V 1pF 18MHz AD818 8 90 VIN 150
7 6 GAIN (dB) 5
ⴞ
15V
ⴞ
5V 4 10 3 0% +5V 2 2V 1 1M 10M 100M 1G FREQUENCY (Hz)
TPC 20. Closed-Loop Gain vs. Frequency (G = +2) TPC 23. Inverter Large Signal Pulse Response; VS = ±5 V, CF = 1 pF, RL = 1 kW
10 0.1dB 2pF 8 V 200mV 10ns S FLATNESS 6
ⴞ
15V 72MHz 1k 1k
⍀ ⍀ ⴞ
5V 34MHz V 100 OUT +5V 19MHz 90 4 AD818 VIN 150
2 0 GAIN (dB) –2 +5V
ⴞ
15V –4 10 –6 0%
ⴞ
5V –8 200mV –10 1M 10M 100M 1G FREQUENCY (Hz)
TPC 21. Closed-Loop Gain vs. Frequency (G = –1) TPC 24. Inverter Small Signal Pulse Response; VS = ±5 V, CF = 1 pF, RL = 150 W –8– REV. D Document Outline Untitled
