Datasheet OP285 (Analog Devices) - 6
Description | Dual 9 MHz Precision Operational Amplifier |
Pages / Page | 15 / 6 — OP285. 250. TA= 25. A = 25. 402. OP AMPS. VS = 15V. 200. +0.1%. +0.01%. … |
Revision | C |
File Format / Size | PDF / 328 Kb |
OP285. 250. TA= 25. A = 25. 402. OP AMPS. VS = 15V. 200. +0.1%. +0.01%. –SR. 150. V/ –. UNITS 100. STEP SIZE. SLEW RATE. +SR. –0.1%. –0.01%. –10
OP285 250 10 50 TA= 25 C T 8 A = 25 C 402 OP AMPS VS = 15V 200 45 6 +0.1% +0.01% –SR 4 S 40 V 150 – 2 V/ – 0 35 UNITS 100 –2 STEP SIZE 30 –4 SLEW RATE +SR 50 –6 –0.1% –0.01% 25 –8 0 –10 20 –250 –200–150 –100 –50 0 50 100 150 200 250 0 100 200 300 400 500 600 700 800 900 0 100 200 300 400 500 INPUT OFFSET – V SETTLING TIME – ns CAPACITIVE LOAD – pF
TPC 19. Input Offset (V TPC 21. Slew Rate vs. OS) TPC 20. Settling Time vs. Step Size Distribution Capacitive Load
100 100 100 90 90 90 10 10 10 0% 0% 0% 5V 200nS 5V 200nS 50mV 100nS
TPC 22. Negative Slew Rate TPC 23. Positive Slew Rate TPC 24. Small Signal Response R R L =2 kΩ, VS = ±15 V, AV = +1 RL = 2 kΩ, VS = ±15 V, AV = +1 L =2 kΩ, VS = ±15 V, AV = +1
CH A: 80.0 V FS 10.0 V/DIV MKR: 6.23 V/ Hz 0 Hz 2.5 KHz MKR: 1 000 Hz BW: 15.0 MHz
TPC 25. OP285 Voltage Noise Density vs. Frequency VS = ±15 V, AV = 1000 –6– REV. C
