Datasheet AD811 (Analog Devices) - 6
DescriptionHigh Performance Video Op Amp
Pages / Page20 / 6 — AD811. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.10. 0.20. RF = …
RevisionG
File Format / SizePDF / 427 Kb
AD811. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.10. 0.20. RF = 649. 0.09. 0.18. C = 3.58MHz. 100 IRE. 0.08. MODULATED RAMP. 0.16
AD811 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 0.10 0.20 RF = 649 0.09 0.18 C = 3.58MHz 100 IRE 0.08 MODULATED RAMP 0.16
AD811 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 0.10 0.20 35 RF = 649
0.09 F 0.18 C = 3.58MHz 100 IRE 30 0.08 MODULATED RAMP 0.16 RL = 150
0.07 0.14 25 VS = ±15V 0.06 0.12 20 0.05 0.10 15 0.04 PHASE 0.08 0.03 0.06 DIFFERENTIAL GAIN (%) 10 OUTPUT VOLTAGE (V p-p) V 0.02 0.04 S = ±5V DIFFERENTIAL PHASE (DEGREES) GAIN 5 0.01 0.02 0 0 0 5 6 7 8 9 10 11 12 13 14 15 10 100 1k 10k SUPPLY VOLTAGE (±V)
00866-E-005
LOAD RESISTANCE (
00866-E-009 Figure 5. Differential Gain and Phase Figure 8. Output Voltage Swing vs. Resistive Load
12 10 G = +2 5 NONINVERTING INPUT 9 RL = 150
±5 TO ±15V RG = RFB 0 6 VS = ±15V VS = ±5V –5 INVERTING INPUT 3 VS = ±5V –10 GAIN (dB) VS = ±15V –15 0 –20 –3 MASTER CLOCK FREQUENCY (MHz) –25 –6 –30 1 10 100 –60 –40 –20 0 20 40 60 80 100 120 140 FREQUENCY (MHz) JUNCTION TEMPERATURE (°C)
00866-E-006 00866-E-010 Figure 6. Frequency Response Figure 9. Input Bias Current vs. Junction Temperature
20 20 V) ± V) ± T T A = 25°C A = 25°C 15 15 RL = 150
10 10 NO LOAD 5 5 COMMON-MODE VOLTAGE RANGE ( MAGNITUDE OF THE OUTPUT VOLTAGE ( 0 0 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE (±V)
00866-E-008
SUPPLY VOLTAGE (±V)
00866-E-011 Figure 7. Input Common-Mode Voltage Range vs. Supply Voltage Figure 10. Output Voltage Swing vs. Supply Voltage Rev. G | Page 6 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION METALIZATION PHOTOGRAPH ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GENERAL DESIGN CONSIDERATIONS ACHIEVING THE FLATTEST GAIN RESPONSE AT HIGH FREQUENCY Choice of Feedback and Gain Resistors Printed Circuit Board Layout Considerations Quality of Coaxial Cable Power Supply Bypassing Driving Capacitive Loads OPERATION AS A VIDEO LINE DRIVER AN 80 MHZ VOLTAGE-CONTROLLED AMPLIFIER CIRCUIT A VIDEO KEYER CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
