AD743 Figures 4 and 5 show two ways to buffer and amplify the output of –100 a charge output transducer. Both require using an amplifier that –110 has a very high input impedance, such as the AD743. Figure 4 –120Hz shows a model of a charge amplifier circuit. Here, amplifica- /TOTAL–130OUTPUT tion depends on the principle of conservation of charge at the –140NOISE input of amplifier A1, which requires that the charge on capaci- –150 tor CS be transferred to capacitor CF, thus yielding an output –160 voltage of ∆Q/C NOISE F. The amplifier’s input voltage noise will appear at –170DUE TO the output amplified by the noise gain (1 + (CS/CF)) of the circuit. R–180B ALONE–190CFNOISEDECIBELS REFERENCED TO 1V–200DUE TORB*R1I–210B ALONER2–2200.010.11101001k10k100kFREQUENCY (Hz)CA1S Figure 6. Noise at the Outputs of the Circuits of CCR1S Figures 4 and 5. Gain = +10, C B*R= S = 3000 pF, RB = 22 MΩ B*R2CF However, this does not change the noise contribution of RB which, *OPTIONAL, SEE TEXT in this example, dominates at low frequencies. The graph of Figure 4. Charge Amplifier Circuit Figure 7 shows how to select an RB large enough to minimize this resistor’s contribution to overall circuit noise. When the R1 equivalent current noise of RB ((√4kT)/R equals the noise of IB (√2qIB), there is diminishing return in making R C B larger. B*5.2 ⴛ 1010RB*A2R2CSRB5.2 ⴛ 109*OPTIONAL, SEE TEXT) ⍀ Figure 5. Model for a High Z Follower with Gain 5.2 ⴛ 108 The circuit in Figure 5 is simply a high impedance follower with gain. Here the noise gain (1 + (R1/R2)) is the same as the gain RESISTANCE ( from the transducer to the output. In both circuits, resistor RB is 5.2 ⴛ 107 required as a dc bias current return. There are three important sources of noise in these circuits. Amplifiers A1 and A2 contribute both voltage and current noise, 5.2 ⴛ 106 while resistor R 1pA10pA100pA1nA10nA B contributes a current noise of INPUT BIAS CURRENT ˜ T N = 4k f ∆ Figure 7. Graph of Resistance vs. Input Bias Current R Where the Equivalent Noise √4kT/R, Equals the Noise B of the Bias Current √2qIB where To maximize dc performance over temperature, the source k = Boltzman’s Constant = 1.381 × 10–23 joules/kelvin resistances should be balanced on each input of the amplifier. T = Absolute Temperature, kelvin (0°C = 273.2 kelvin) This is represented by the optional resistor R B in Figures 4 and 5. f = Bandwidth—in Hz (assuming an ideal “brick wall” filter) As previously mentioned, for best noise performance, care should This must be root-sum-squared with the amplifier’s own be taken to also balance the source capacitance designated by CB. current noise. The value for CB in Figure 4 would be equal to CS in Figure 5. Figure 6 shows that these circuits in Figures 4 and 5 have an At values of CB over 300 pF, there is a diminishing impact on identical frequency response and noise performance (provided noise; capacitor CB can then be simply a large bypass of 0.01 µF that C or greater. S/CF = R1/ R2). One feature of the first circuit is that a “T” network is used to increase the effective resistance of RB and to improve the low frequency cutoff point by the same factor. –8– REV. E Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS CONNECTION DIAGRAMS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD SUSCEPTIBILITY ORDERING GUIDE Typical Performance Characteristics OP AMP PERFORMANCE: JFET VS. BIPOLAR DESIGNING CIRCUITS FOR LOW NOISE LOW NOISE CHARGE AMPLIFIERS HOW CHIP PACKAGE TYPE AND POWER DISSIPATION AFFECT INPUT BIAS CURRENT REDUCED POWER SUPPLY OPERATION FOR LOWER IB AN INPUT IMPEDANCE COMPENSATED, SALLEN-KEY FILTER TWO HIGH PERFORMANCE ACCELEROMETER AMPLIFIERS LOW NOISE HYDROPHONE AMPLIFIER BALANCING SOURCE IMPEDANCES OUTLINE DIMENSIONS Revision History
