Datasheet ER18505 (EEMB) - 9
ManufacturerEEMB
DescriptionLithium Thionyl Chloride Battery
Pages / Page9 / 9 — Document Name. Document No. Date. Page. ER18505. Specification. …
File Format / SizePDF / 621 Kb
Document Name. Document No. Date. Page. ER18505. Specification. ZJQM-RD-SPC-H0329. 2019-04-19. 9/9. ! Warning
Document Name Document No Date Page ER18505 Specification ZJQM-RD-SPC-H0329 2019-04-19 9/9 ! Warning
Document Name Document No. Date Page ER18505 Specification ZJQM-RD-SPC-H0329 2019-04-19 9/9
机溶剂,上述任何操作都可能导致其爆炸或损坏。  DO NOT over-discharge the battery. In case the battery is over-discharged battery has potential of explosion. In case battery is over discharged, when connected with exterior power source or connected with other batteries in series, explosion may occur. 请勿过度放电。 如果电池过度放电,电池可能会爆炸。 如果电池过放电,当与外部电源连接或与 其他电池串联时,可能会发生爆炸。  Keep this battery out of the reach of children. If it is swallowed, contact a physician immediately. 请将此电池放在儿童接触不到的地方。如果吞下,请立即联系医生。  When storing a battery or throwing it away, be sure to cover it with tape. If the battery is contacted with other metal objects, it could cause fire or become damaged. 存放电池或丢弃电池时,请务必用胶带包住电池。如果电池与其他金属物体接触,可能会引起火灾 或损坏。
! Warning
警告  Thoroughly read the user’s manual before use, inaccurate handling may cause leakage, heat, smoke, explosion, or fire, causing device trouble or injury. 使用前请仔细阅读用户手册,不准确的操作可能会导致泄漏,发热,冒烟,爆炸或起火,从而导致 设备故障或人员受伤。  Insert the battery with the "+" and "-" ends correctly oriented. 插入电池时,注意“+”极和“-”极方向正确。  If the battery is used together with new batteries, do not use it with a different type battery. 如果电池与新电池一起使用,请勿将其与其他类型的电池混用。  Do not solder the battery directly. 请勿直接焊接电池。  Avoid storing the battery in direct sunlight, or in excessively hot and humid place. 避免将电池存放在阳光直射或过热和潮湿的地方。 EEMB reserves the final explanation. Please use battery strictly according to specification. EEMB will not be responsible for any inappropriate operation. EEMB keeps the right to change product specifications without previous notice. If any question, please consult with the manufacturer EEMB 保留最终解释权。请严格按照规范使用电池。EEMB 对任何不当操作将不负责。EEMB 保留修改产品规格书不另行通知 的权利。如有任何问题,请咨询制造商。
