Datasheet BLF989E, BLF989ES (Ampleon) - 10
Manufacturer | Ampleon |
Description | UHF power LDMOS transistor |
Pages / Page | 12 / 10 — BLF989E; BLF989ES. UHF power LDMOS transistor. 12. Legal information. … |
File Format / Size | PDF / 1.2 Mb |
BLF989E; BLF989ES. UHF power LDMOS transistor. 12. Legal information. 12.1 Data. sheet. status. Document status[1][2]
![BLF989E; BLF989ES UHF power LDMOS transistor 12 Legal information 12.1 Data sheet status Document status[1][2]](https://www.rlocman.ru/datasheet/img.php?di=170657&p=9)
link to page 10 link to page 10 link to page 10
BLF989E; BLF989ES UHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition
Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com.
12.2 Definitions Right to make changes —
Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This
Draft —
The document is a draft version only. The content is still under document supersedes and replaces all information supplied prior to the internal review and subject to formal approval, which may result in publication hereof. modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein
Suitability for use —
Ampleon products are not designed, authorized or and shall have no liability for the consequences of use of such information. warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an
Short data sheet —
A short data sheet is an extract from a full data sheet Ampleon product can reasonably be expected to result in personal injury, with the same product type number(s) and title. A short data sheet is intended death or severe property or environmental damage. Ampleon and its for quick reference only and should not be relied upon to contain detailed and suppliers accept no liability for inclusion and/or use of Ampleon products in full information. For detailed and full information see the relevant full data such equipment or applications and therefore such inclusion and/or use is at sheet, which is available on request via the local Ampleon sales office. In the customer’s own risk. case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail.
Applications —
Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation
Product specification —
The information and data provided in a Product or warranty that such applications will be suitable for the specified use without data sheet shall define the specification of the product as agreed between further testing or modification. Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid Customers are responsible for the design and operation of their applications in which the Ampleon product is deemed to offer functions and qualities and products using Ampleon products, and Ampleon accepts no liability for beyond those described in the Product data sheet. any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the
12.3 Disclaimers
planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products.
Maturity —
The information in this document can only be regarded as final once the relevant product(s) has passed the Release Gate in Ampleon's Ampleon does not accept any liability related to any default, damage, costs or release process. Prior to such release this document should be regarded as a problem which is based on any weakness or default in the customer’s draft version. applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the
Limited warranty and liability —
Information in this document is believed to customer’s applications and products using Ampleon products in order to be accurate and reliable. However, Ampleon does not give any avoid a default of the applications and the products or of the application or representations or warranties, expressed or implied, as to the accuracy or use by customer’s third party customer(s). Ampleon does not accept any completeness of such information and shall have no liability for the liability in this respect. consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of
Limiting values —
Stress above one or more limiting values (as defined in Ampleon. the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) In no event shall Ampleon be liable for any indirect, incidental, punitive, operation of the device at these or any other conditions above those given in special or consequential damages (including - without limitation - lost profits, the Recommended operating conditions section (if present) or the lost savings, business interruption, costs related to the removal or Characteristics sections of this document is not warranted. Constant or replacement of any products or rework charges) whether or not such repeated exposure to limiting values will permanently and irreversibly affect damages are based on tort (including negligence), warranty, breach of the quality and reliability of the device. contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason
Terms and conditions of commercial sale —
Ampleon products are sold whatsoever, Ampleon’s aggregate and cumulative liability towards customer subject to the general terms and conditions of commercial sale, as published for the products described herein shall be limited in accordance with the at http://www.ampleon.com/terms, unless otherwise agreed in a valid written Terms and conditions of commercial sale of Ampleon. individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. BLF989E_BLF989ES All information provided in this document is subject to legal disclaimers. © Ampleon Netherlands B.V. 2020. All rights reserved.
Product data sheet Rev. 1 — 3 April 2020 10 of 12
Document Outline 1. Product profile 1.1 General description 1.2 Features and benefits 1.3 Applications 2. Pinning information 3. Ordering information 4. Limiting values 5. Thermal characteristics 6. Characteristics 7. Test information 7.1 Ruggedness in Doherty operation 7.2 Test circuit 7.3 Graphs 7.3.1 DVB-T in production test circuit 8. Package outline 9. Handling information 10. Abbreviations 11. Revision history 12. Legal information 12.1 Data sheet status 12.2 Definitions 12.3 Disclaimers 12.4 Licenses 12.5 Trademarks 13. Contact information 14. Contents
