Datasheet LTC3884, LTC3884-1 (Analog Devices) - 100
DescriptionDual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management
Pages / Page128 / 100 — PMBus COMMAND DETAILS Fault Sharing Response. DATA. DEFAULT. COMMAND …
RevisionF
File Format / SizePDF / 4.1 Mb
PMBus COMMAND DETAILS Fault Sharing Response. DATA. DEFAULT. COMMAND NAME. CMD CODE DESCRIPTION. TYPE. PAGED FORMAT UNITS. NVM. VALUE
PMBus COMMAND DETAILS Fault Sharing Response DATA DEFAULT COMMAND NAME CMD CODE DESCRIPTION TYPE PAGED FORMAT UNITS NVM VALUE
LTC3884/LTC3884-1
MFR_FAULT_RESPONSE 0xD5 Action to be taken by the device when the R/W Byte Y Reg Y 0xC0 FAULT pin is asserted low.
MFR_FAULT_RESPONSE
The MFR_FAULT_RESPONSE command instructs the device on what action to take in response to the FAULTn pin being pulled low by an external source.
Supported Values: VALUE MEANING
0xC0 FAULT_INHIBIT The LTC3884 will three-state the output in response to the FAULT pin pulled low. 0x00 FAULT_IGNORE The LTC3884 continues operation without interruption. The device also: • Sets the MFR Bit in the STATUS_WORD. • Sets Bit 0 in the STATUS_MFR_SPECIFIC Command to Indicate FAULTn Is Being Pulled Low • Notifies the Host by Asserting ALERT, Unless Masked This command has one data byte.
SCRATCHPAD DATA DEFAULT COMMAND NAME CMD CODE DESCRIPTION TYPE PAGED FORMAT UNITS NVM VALUE
USER_DATA_00 0xB0 OEM reserved. Typically used for part R/W Word N Reg Y NA serialization. USER_DATA_01 0xB1 Manufacturer reserved for LTpowerPlay. R/W Word Y Reg Y NA USER_DATA_02 0xB2 OEM reserved. Typically used for part R/W Word N Reg Y NA serialization. USER_DATA_03 0xB3 A NVM word available for the user. R/W Word Y Reg Y 0x0000 USER_DATA_04 0xB4 A NVM word available for the user. R/W Word N Reg Y 0x0000 Rev. F 100 For more information www.analog.com Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Overview Main Control Loop EEPROM Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC/EXTVCC Power Output Current Sensing and Sub Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins CRC Protection and ECC Serial Interface Communication Protection Device Addressing Responses to VOUT, IIN and IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface PMBus Command Summary PMBus Commands *Data Format Applications Information Current Limit Programming ISENSE0± and ISENSE1± Pins Inductor DCR Sensing Inductor Value Calculation Inductor Core Selection Low Value Resistor Current Sensing Slope Compensation and Inductor Peak Current Power MOSFET and Optional Schottky Diode Selection Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) INTVCC/EXTVCC Power Topside MOSFET Driver Supply (CB, DB) Undervoltage Lockout CIN and COUT Selection Fault Indication Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Minimum On-Time Considerations External Temperature Sense Input Current Sense Amplifier External Resistor Configuration Pins (RCONFIG) Voltage Selection Frequency Selection Phase Selection Address Selection Using RCONFIG Efficiency Considerations Programmable Loop Compensation Checking Transient Response PolyPhase Configuration Master Slave Operation PC Board Layout Checklist PC Board Layout Debugging Design Example Additional Design Checks Connecting the USB to I2C/SMBus/PMBus Controller to the LTC3884 in System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry NVM Memory Commands Store/Restore Fault Log Operation Fault Logging Block Memory Write/Read Typical Applications Package Description Revision History Typical Application Related Parts
