Datasheet LTC3882-1 (Analog Devices) - 2
DescriptionDual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
Pages / Page108 / 2 — TABLE OF CONTENTS. Features ... 1. PMBus Command Summary ..37. …
File Format / SizePDF / 3.3 Mb
TABLE OF CONTENTS. Features ... 1. PMBus Command Summary ..37. Applications .. 1. Typical Application .. 1. Description.. 1
TABLE OF CONTENTS Features .. 1 PMBus Command Summary ..37 Applications . 1 Typical Application . 1 Description. 1
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 4 link to page 4 link to page 5 link to page 9 link to page 13 link to page 15 link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 19 link to page 20 link to page 20 link to page 20 link to page 20 link to page 21 link to page 21 link to page 21 link to page 21 link to page 22 link to page 22 link to page 22 link to page 22 link to page 22 link to page 23 link to page 23 link to page 24 link to page 24 link to page 24 link to page 24 link to page 25 link to page 25 link to page 25 link to page 25 link to page 26 link to page 26 link to page 26 link to page 26 link to page 28 link to page 28 link to page 31 link to page 32 link to page 32 link to page 36 link to page 36 link to page 37 link to page 37 link to page 37 link to page 42 link to page 42 link to page 42 link to page 43 link to page 44 link to page 44 link to page 44 link to page 45 link to page 46 link to page 47 link to page 48 link to page 50 link to page 51 link to page 51 link to page 52 link to page 54 link to page 54 link to page 55 link to page 56 link to page 60 link to page 60 link to page 62 link to page 62 link to page 63 link to page 63 link to page 64 link to page 65 link to page 65 link to page 66 link to page 66 link to page 69 link to page 69 link to page 69 link to page 69 link to page 70 link to page 70 link to page 71 link to page 71 link to page 71 link to page 71 link to page 71 link to page 72 link to page 72 link to page 72 link to page 73 link to page 73 link to page 74 link to page 74 LTC3882-1
TABLE OF CONTENTS Features ... 1 PMBus Command Summary ..37 Applications .. 1
PMBus Commands ...37
Data Formats ..37
Description.. 1 Applications Information ..42 Absolute Maximum Ratings .. 4
Efficiency Considerations ...42
Order Information .. 4
PWM Frequency and Inductor Selection ...42
Pin Configuration .. 4
Power MOSFET Selection ...43
Electrical Characteristics ... 5
MOSFET Driver Selection ...44
Typical Performance Characteristics ... 9
Using PWM Protocols ..44
Pin Functions ..13
CIN Selection ...44
Block Diagram ...15
COUT Selection ..45
Test Circuit ...16
Feedback Loop Compensation ..46
Timing Diagram ...16
PCB Layout Considerations ..47
Operation...16
Output Current Sensing ..48 Overview .. 16 Output Voltage Sensing ..50 Main Control Loop .. 17 Soft-Start and Stop .. 51 Power-Up and Initialization ... 19 Time-Based Output Sequencing and Ramping ... 51 Soft-Start ...20 Voltage-Based Output Sequencing ...52 Time-Based Output Sequencing ...20 Using Output Voltage Servo ...54 Output Ramping Control ...20 Using AVP ..54 Voltage-Based Output Sequencing ...20 PWM Frequency Synchronization ...55 Minimum Output Disable Times ...21 PolyPhase Operation and Load Sharing ...56 Output Short Cycle ...21 External Temperature Sense ...60 Light Load Current Operation ...21 Resistor Configuration Pins ..60 Switching Frequency and Phase ...21 Internal Regulator Outputs ...62 PolyPhase Load Sharing ...22 IC Junction Temperature...62 Active Voltage Positioning ..22 Derating EEPROM Retention at Temperature ..63 Input Supply Monitoring ...22 Configuring Open-Drain Pins ..63 Output Voltage Sensing and Monitoring ...22 PMBus Communication and Command Processing ..64 Output Current Sensing and Monitoring ...22 Status and Fault Log Management ...65 External and Internal Temperature Sense ...23 LTpowerPlay – An Interactive Digital Power GUI ... 65 Resistor Configuration Pins ..23 Interfacing to the DC1613 ...66 Internal EEPROM with CRC and ECC .. 24 Design Example ..66 Fault Detection .. 24
PMBus COMMAND DETAILS ...69
Input Supply Faults ... 24 Addressing and Write Protect ...69 Hardwired PWM Response to VOUT Faults ...24 PAGE ..69 Power Good Indication (Master) ...25 PAGE_PLUS_WRITE ..69 Power Good Indication (Slave) ...25 PAGE_PLUS_READ ..70 Hardwired PWM Response to IOUT Faults ..25 WRITE_PROTECT ...70 Hardwired PWM Response to Temperature Faults .. 25 MFR_ADDRESS ...71 Hardwired PWM Response to Timing Faults ..26 MFR_RAIL_ADDRESS ...71 External Faults ..26 General Device Configuration ...71 Fault Handling ...26 PMBUS_REVISION ...71 Status Registers and
ALERT
Masking ...26 CAPABILITY ..71 FAULT Pin I/O ..28 On, Off and Margin Control ...72 Fault Logging ..28 ON_OFF_CONFIG ..72 Factory Default Operation ...31 MFR_CONFIG_ALL_LTC3882-1 ...72 Serial Interface ...32 OPERATION ..73 Serial Bus Addressing ..32 MFR_RESET ...73 Serial Bus Timeout ...36 PWM Configuration .. 74 Serial Communication Errors..36 FREQUENCY_SWITCH .. 74 Rev B 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit Timing Diagram Operation Overview Main Control Loop Power-Up and Initialization Soft-Start Time-Based Output Sequencing Output Ramping Control Voltage-Based Output Sequencing Minimum Output Disable Times Output Short Cycle Light Load Current Operation Switching Frequency and Phase PolyPhase Load Sharing Active Voltage Positioning Input Supply Monitoring Output Voltage Sensing and Monitoring Output Current Sensing and Monitoring External and Internal Temperature Sense Resistor Configuration Pins Internal EEPROM with CRC and ECC Fault Detection Input Supply Faults Hardwired PWM Response to VOUT Faults Power Good Indication (Master) Power Good Indication (Slave) Hardwired PWM Response to IOUT Faults Hardwired PWM Response to Temperature Faults Hardwired PWM Response to Timing Faults External Faults Fault Handling Status Registers and ALERT Masking FAULT Pin I/O Fault Logging Factory Default Operation Serial Interface Serial Bus Addressing Serial Bus Timeout Serial Communication Errors PMBus Command Summary PMBus Commands Data Formats Applications Information Efficiency Considerations PWM Frequency and Inductor Selection Power MOSFET Selection MOSFET Driver Selection Using PWM Protocols CIN Selection COUT Selection Feedback Loop Compensation PCB Layout Considerations Output Current Sensing Output Voltage Sensing Soft-Start and Stop Time-Based Output Sequencing and Ramping Voltage-Based Output Sequencing Using Output Voltage Servo Using AVP PWM Frequency Synchronization PolyPhase Operation and Load Sharing External Temperature Sense Resistor Configuration Pins Internal Regulator Outputs IC Junction Temperature Derating EEPROM Retention at Temperature Configuring Open-Drain Pins PMBus Communication and Command Processing Status and Fault Log Management LTpowerPlay – An Interactive Digital Power GUI Interfacing to the DC1613 Design Example PMBus COMMAND DETAILS Addressing and Write Protect PAGE PAGE_PLUS_WRITE PAGE_PLUS_READ WRITE_PROTECT MFR_ADDRESS MFR_RAIL_ADDRESS General Device Configuration PMBUS_REVISION CAPABILITY On, Off and Margin Control ON_OFF_CONFIG MFR_CONFIG_ALL_LTC3882-1 OPERATION MFR_RESET PWM Configuration FREQUENCY_SWITCH MFR_PWM_CONFIG_LTC3882-1 MFR_CHAN_CONFIG_LTC3882-1 MFR_PWM_MODE_LTC3882-1 Input Voltage and Limits VIN_ON VIN_OFF VIN_OV_FAULT_LIMIT VIN_UV_WARN_LIMIT Output Voltage and Limits VOUT_MODE VOUT_COMMAND MFR_VOUT_MAX VOUT_MAX MFR_VOUT_AVP VOUT_MARGIN_HIGH VOUT_MARGIN_LOW VOUT_OV_FAULT_LIMIT VOUT_OV_WARN_LIMIT VOUT_UV_WARN_LIMIT VOUT_UV_FAULT_LIMIT Output Current and Limits IOUT_CAL_GAIN MFR_IOUT_CAL_GAIN_TC IOUT_OC_FAULT_LIMIT IOUT_OC_WARN_LIMIT Output Timing, Delays, and Ramping MFR_RESTART_DELAY TON_DELAY TON_RISE TON_MAX_FAULT_LIMIT VOUT_TRANSITION_RATE TOFF_DELAY TOFF_FALL TOFF_MAX_WARN_LIMIT External Temperature and Limits MFR_TEMP_1_GAIN MFR_TEMP_1_OFFSET OT_FAULT_LIMIT OT_WARN_LIMIT Status Reporting STATUS_BYTE UT_FAULT_LIMIT STATUS_WORD STATUS_VOUT STATUS_IOUT STATUS_INPUT STATUS_TEMPERATURE STATUS_CML STATUS_MFR_SPECIFIC MFR_PADS_LTC3882-1 MFR_COMMON MFR_INFO CLEAR_FAULTS Telemetry READ_VIN MFR_VIN_PEAK READ_VOUT MFR_VOUT_PEAK READ_IOUT MFR_IOUT_PEAK READ_POUT READ_TEMPERATURE_1 MFR_TEMPERATURE_1_PEAK READ_TEMPERATURE_2 MFR_TEMPERATURE_2_PEAK READ_DUTY_CYCLE READ_FREQUENCY MFR_CLEAR_PEAKS Fault Response and Communication VIN_OV_FAULT_RESPONSE VOUT_OV_FAULT_RESPONSE VOUT_UV_FAULT_RESPONSE IOUT_OC_FAULT_RESPONSE OT_FAULT_RESPONSE UT_FAULT_RESPONSE MFR_OT_FAULT_RESPONSE TON_MAX_FAULT_RESPONSE MFR_RETRY_DELAY SMBALERT_MASK MFR_FAULT_PROPAGATE_LTC3882-1 MFR_FAULT_RESPONSE MFR_FAULT_LOG Fault Log Operation MFR_FAULT_LOG_CLEAR EEPROM User Access STORE_USER_ALL RESTORE_USER_ALL MFR_COMPARE_USER_ALL MFR_FAULT_LOG_STORE MFR_EE_xxxx USER_DATA_0x Unit Identification MFR_ID MFR_MODEL MFR_SERIAL MFR_SPECIAL_ID Typical Applications Package Description Revision History Typical Application Related Parts
