Datasheet LTC3890-2 (Analog Devices)
Description60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller
Pages / Page42 / 1 — FEATURES. DESCRIPTION. Wide VIN Range: 4V to 60V (65V Abs Max). Low …
RevisionA
File Format / SizePDF / 958 Kb
FEATURES. DESCRIPTION. Wide VIN Range: 4V to 60V (65V Abs Max). Low Operating IQ: 50µA (One Channel On)
Datasheet LTC3890-2 Analog Devices, Revision: A
link to page 11 LTC3890-2 60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller
FEATURES DESCRIPTION
n
The LTC®3890-2 is a high performance dual step-down n
switching regulator DC/DC controller that drives all n
Wide Output Voltage Range: 0.8V ≤ VOUT ≤ 24V
N-channel synchronous power MOSFET stages. A constant n
RSENSE or DCR Current Sensing
frequency current mode architecture allows a phase- n Out-of-Phase Controllers Reduce Input Capacitance lockable frequency of up to 850kHz. Power loss and noise and Power Supply Induced Noise due to the ESR of the input capacitor are minimized by n Phase-Lockable Frequency (75kHz to 850kHz) operating the two controller output stages out-of-phase. n Programmable Fixed Frequency (50kHz to 900kHz) The 50μA no-load quiescent current extends operating run n Selectable Continuous, Pulse-Skipping or Low Ripple time in battery-powered systems. OPTI-LOOP® compensa- Burst Mode® Operation at Light Loads tion allows the transient response to be optimized over a n Selectable Current Limit wide range of output capacitance and ESR values. A wide n Very Low Dropout Operation: 99% Duty Cycle 4V to 60V input supply range encompasses a wide range n Adjustable Output Voltage Soft-Start or Tracking of intermediate bus voltages and battery chemistries. n Power Good Output Voltage Monitors n Low Shutdown IQ : < 14µA Independent TRACK/SS pins for each controller ramp the n Internal LDO Powers Gate Drive from VIN or EXTVCC output voltages during start-up. Current mode control limits n Small Low Profile (0.75mm) 5mm × 5mm QFN Package the inductor current during short-circuit conditions. The n AEC-Q100 Qualified for Automotive Applications PLLIN/MODE pin selects among Burst Mode operation, pulse-skipping mode, or continuous conduction mode at
light loads. For versions with different and/or additional features, see the LTC3890 family summary, Table 1, in the n Automotive Always-On Systems Pin Functions section of this data sheet. n Battery Operated Digital Devices All registered trademarks and trademarks are the property of their respective owners. Protected n Distributed DC Power Systems by U.S. patents, including 5481178, 5705919, 5929620, 6100678, 6144194, 6177787, 6304066, 6580258, 7230497.
TYPICAL APPLICATION High Efficiency Dual 8.5V/3.3V Output Step-Down Converter Efficiency and Power Loss
VIN
vs Output Current
9V TO 60V 22µF 4.7µF 100 10000 VIN = 12V VIN INTVCC 90 VOUT = 3.3V TG1 TG2 0.1µF 80 1000 0.1µF BOOST1 BOOST2 POWER LOSS (mW) 4.7µH 8µH 70 SW1 SW2 60 100 BG1 BG2 50 LTC3890-2 PGND 40 10 EFFICIENCY (%) SENSE1+ SENSE2+ 30 0.008Ω 0.01Ω 20 1 V SENSE1– SENSE2– VOUT2 10 OUT1 3.3V 8.5V VFB1 VFB2 0 0.1 5A 100k ITH1 ITH2 100k 3A 0.0001 0.001 0.01 0.1 1 10 470µF 1000pF 1000pF TRACK/SS1 SGND TRACK/SS2 330µF OUTPUT CURRENT (A) 10.5k 38902 TA01b 31.6k 34.8k 34.8k 0.1µF 0.1µF 38902 TA01a Rev. A Document Feedback For more information www.analog.com 1 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
