Datasheet MAX6605 (Maxim) - 3
Manufacturer | Maxim |
Description | Low-Power Analog Temperature Sensor in SC70 Package |
Pages / Page | 6 / 3 — Low-Power Analog Temperature Sensor. in SC70 Package. MAX6605. Typical … |
File Format / Size | PDF / 123 Kb |
Low-Power Analog Temperature Sensor. in SC70 Package. MAX6605. Typical Operating Characteristics. TEMPERATURE ERROR
Low-Power Analog Temperature Sensor in SC70 Package MAX6605 Typical Operating Characteristics
(VCC = +3.3V, CS = 0.1µF, CL = 1nF, unless otherwise noted.)
TEMPERATURE ERROR SUPPLY CURRENT OUTPUT VOLTAGE vs. TEMPERATURE vs. TEMPERATURE vs. SUPPLY VOLTAGE
6 2.2 1.7 2.0 1.5 1.3 5 1.8 MAX6605 toc01 MAX6605 toc02 MAX6605 toc03 1.1 °C) TA = +25°C 1.6 0.9 μA) 0.7 4 1.4 0.5 1.2 0.3 3 1.0 0.1 -0.1 0.8 OUTPUT VOLTAGE (V) -0.3 2 SUPPLY CURRENT ( 0.6 TEMPERATURE ERROR ( -0.5 0.4 -0.7 1 -0.9 0.2 -1.1 0 -1.3 0 -55 -35 -15 5 25 45 65 85 105 125 -55 -35 -15 5 25 45 65 85 105 125 0 1 2 3 4 5 TEMPERATURE (°C) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
SUPPLY CURRENT OUTPUT VOLTAGE STEP-RESPONSE FROM +25
C TO +100
C vs. TEMPERATURE vs. SUPPLY VOLTAGE (FLUORINERT BATH)
7 1.060 6 1.055 V MAX6605 toc04 CC = +5V MAX6605 toc05 MAX6605 toc06 1.050 5 μA) VCC = +3.3V 1.045 4 OUT 1.040 500mV/div VCC = +2.4V 3 TA = +25°C 1.035 SUPPLY CURRENT ( OUTPUT VOLTAGE (V) 2 1.030 1 1.025 0 1.020 0 -55 -35 -15 5 25 45 65 85 105 125 0 1 2 3 4 5 6 1s/div TEMPERATURE (°C) SUPPLY VOLTAGE (V)
_______________________________________________________________________________________ 3
