Datasheet MYTNA1R86RELA2RA (Murata) - 6
Manufacturer | Murata |
Description | UltraBK 6A DC–DC Converter Module |
Pages / Page | 26 / 6 — MYTNA1R86RELA2RA. Document Category: Datasheet UltraBK™ 6A DC–DC … |
File Format / Size | PDF / 1.6 Mb |
MYTNA1R86RELA2RA. Document Category: Datasheet UltraBK™ 6A DC–DC Converter Module. Pin Descriptions. PIN NO. A1-A3, B2-B3
MYTNA1R86RELA2RA
Pin Descriptions
A4-A6, B4-B6, C2C5, D2-D5,E2-E5,
F2-F5, G1-G3, H1H3 NAME DESCRIPTION Input Voltage pins. Apply input voltage between these
pins and GND pins. Vin GND Ground pins. Connect to the GND plane. B1 ON/OFF C1 POK C6, D6, E6, F6, G6 DNC D1 Trim E1 AGND F1 +Sense G4-G5, H4-H6 Vout Remote ON/OFF pin. This pin is connected to Vin
through the internal resistance.
Power Good pin. The function is operated by internal
open-drain FET.
Do not connect pins. Those pins must be left floating
individually.
Trimming pin. Connect to the resistor to adjust to the
target output voltage.
Analog ground pin. Connect to trimming Resistor.
Output Voltage Sensing pin. Connect to an output near
the load to improve load regulation. This pin must be
connected to output near the load, or at the module
pins.
Output pins. Connect the output load between these
pins and Ground pins. Place external bypass capacitors
as close as possible to these pins to reduce parasitic
inductance.
Table 5. Pin Descriptions Functional Block Diagram Figure 4. Functional Block Diagram http://www.murata.com/products/power
Copyright ©2020 Murata Manufacturing Co., Ltd. All rights reserved.
Export Control Code : X0863 Document No :D90DH -00061 MYTNA1R86RELA2RA A01 Page 6 of 26
