Datasheet PI4ULS3V4857 (Diodes) - 8
ManufacturerDiodes
Description6-BIT Bi-Directional Level Shifter for Sd 3.0-SDR104 Compliant Memory Card Application
Pages / Page11 / 8 — PI4ULS3V4857. Level Translator Dynamic Characteristics. Symbol. …
File Format / SizePDF / 827 Kb
PI4ULS3V4857. Level Translator Dynamic Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Units. Host Side Transition Times
PI4ULS3V4857 Level Translator Dynamic Characteristics Symbol Parameter Conditions Min Typ Max Units Host Side Transition Times
A product Line of Diodes Incorporated
At recommended operating conditions; VCCA = 1.2V; Tamb = 25oC; unless otherwise specified.
Symbol Parameter Conditions Min. Typ. Max. Units Host Side Transition Times
t (1) r Rise time SEL = HIGH (1.8V card interface); 0.4 1.0 ns V t CCA = 1.8V f Fall time (1) 0.4 1.0 ns t (1) r Rise time SEL = HIGH (1.8V card interface); 0.4 1.0 ns V t CCA = 1.2V f Fall time (1) 0.4 1.0 ns
Card Side Transition Times
tr Rise time SEL = HIGH (1.8V card interface); 0.4(2) 0.88 1.32 ns -40oC ≤ T t amb ≤ +85oC f Fall time 0.4(2) 0.88 1.32 ns
Card Input Transition Times
tr Rise time SEL = HIGH (1.8 V card interface); 0.2(3) 0.5 0.96 ns -40oC ≤ T t amb ≤ +85oC f Fall time 0.2(3) 0.45 0.96 ns
Host to Card Propagation Delay
DATxA to DATxB, CMDA to CMDB, CLKA to CLKB
tpd Propagation delay SEL = HIGH (1.8V card interface); VCCA = 1.2V 3.0 5.5 ns
CLKA to CLK_FB
tpd Propagation delay SEL = HIGH (1.8V card interface); VCCA = 1.2V 5.5 10 ns
Card to Host Propagation Delay
DATxB to DATxA, CMDB to CMDA
tpd Propagation delay SEL = HIGH (1.8V card interface); VCCA = 1.2V 2.5 4.5 ns Note: 1. Transition between VOL = 0.35 * VCCA and VOH = 0.65 * VCCA 2. Transition between VOL = 0.45V and VOH = 1.4V 3. Guaranteed by design; transition between VIL = 0.58V and VIH = 1.27V with Ctrace = 3.5 pF and Ccard+CRADLE = 12pF, trace length = 11mm VCC VOH VOL GND tf VOL tf VOH
Figure 3. Output Rise and Fall Times
PI4ULS3V4857 www.diodes.com August 2020 Document Number DS42310 Rev 2-2 8 Diodes Incorporated
