Datasheet MAX4684, MAX4685 (Maxim) - 5
Manufacturer | Maxim |
Description | 0.5Ω/0.8Ω Low-Voltage, Dual SPDT Analog Switches in UCSP |
Pages / Page | 10 / 5 — Typical Operating Characteristics (continued). TURN-ON/TURN-0FF TIMES. … |
File Format / Size | PDF / 2.0 Mb |
Typical Operating Characteristics (continued). TURN-ON/TURN-0FF TIMES. SUPPLY CURRENT vs. SUPPLY VOLTAGE. vs. SUPPLY VOLTAGE
MAX4684/MAX4685 0.5Ω/0.8Ω Low-Voltage, Dual SPDT Analog Switches in UCSP
(TA = +25°C, unless otherwise noted.)
TURN-ON/TURN-0FF TIMES TURN-ON/TURN-0FF TIMES SUPPLY CURRENT vs. SUPPLY VOLTAGE vs. SUPPLY VOLTAGE vs. TEMPERATURE
100 80 50 V+ = +3V 70 45 80 40 MAX4684/5 toc10 60 MAX4684/5 toc11 MAX4684/5 toc12 35 tON 50 tON 60 (ns) 30 (ns) 40 25 /t OFF t /t OFF 40 t ON OFF 30 t ON 20 15 SUPPLY CURRENT (pA) 20 t 20 10 OFF 10 5 0 0 0 0 1 2 3 4 5 6 1.8 2.3 2.8 3.3 3.8 4.3 4.8 5.3 -40 -15 10 35 60 85 VSUPPLY (V) VSUPPLY (V) TEMPERATURE (°C)
MAX4684 LOGIC THRESHOLD VOLTAGE ON/OFF-LEAKAGE CURRENT vs. SUPPLY VOLTAGE CHARGE INJECTION vs. COM VOLTAGE vs. TEMPERATURE
2.0 300 1000 200 1.5 MAX4684/5 toc13 V 100 MAX4684/5 toc14 MAX4684/5 toc15 IN RISING 0 100 1.0 -100 Q (pC) VIN FALLING I -200 COM(ON) 10 0.5 -300 LOGIC THRESHOLD VOLTAGE (V) ON/OFF-LEAKAGE CURRENT (pA) -400 ICOM(OFF) 0 -500 1 0 1 2 3 4 5 6 0 1 2 3 4 5 6 -40 -15 10 35 60 85 VSUPPLY (V) VCOM (V) TEMPERATURE (°C)
MAX4685 ON/OFF-LEAKAGE CURRENT TOTAL HARMONIC DISTORTION vs. TEMPERATURE FREQUENCY RESPONSE (µMAX) PLUS NOISE vs. FREQUENCY
1000 0 0.1 ON- -20 RESPONSE MAX4684/5 toc16 MAX4684/85 toc17 MAX4684/5 toc18 100 -40 OFF- ISOLATION ICOM(ON) -60 CROSSTALK LOSS (dB) THD + N (%) 10 -80 ON/OFF-LEAKAGE CURRENT (pA) ICOM(OFF) -100 1 -120 0.01 -40 -15 10 35 60 85 0.001 0.01 0.1 1 10 100 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (MHz) FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 5
