Datasheet SP6690 (Sipex) - 2
Manufacturer | Sipex |
Description | Micro Power Boost Regulator Series White LED Driver |
Pages / Page | 15 / 2 — ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS. PARAMETER. SYMBOL. … |
File Format / Size | PDF / 384 Kb |
ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS. PARAMETER. SYMBOL. MIN. TYP. MAX. UNITS. CONDITIONS
V ... 15V Storage Temperature .. -65°C to +150°C IN SW Voltage .. -0.4 to 34V Power Dissipation. ... 200mW FB Voltage ... 2.5V ESD Rating ... 2kV HBM All other pins ... -0.3 to V + 0.3V IN Current into FB ... ±1mA T Max ... 125°C J These are stress ratings only and functional operation of the device at Operating Temperature Range .. -40°C to 85°C these ratings or any other above those indicated in the operation sections Peak Output Current < 10us SW .. 500mA of the specifications below is not implied. Exposure to absolute maximum rating conditions for extended periods of time may affect reliability.
Specifications are at TA = 25°C, VIN = 3.3, VSHDN = VIN, ♦ denotes the specifications which apply over the full operating temperature range, unless otherwise specified.
PARAMETER SYMBOL MIN TYP MAX UNITS CONDITIONS
Input Voltage VIN 1.0 13.5 V Supply Current IQ 20 30 µA ♦ No Switching 0.01 1 µA ♦ SHDN = 0V (off) Reference Voltage VFB 1.17 1.22 1.27 V ♦ FB Hysteresis HYST 8 mV VFB Input Bias Current IFB 15 80 nA ♦ VFB = 1.22V Line Regulation ∆Vo/∆VI 0.1 0.3 %/V 1.2 ≤ VIN ≤ 13.5V Switch Off Time TOFF 250 nS VFB > 1V 1200 nS VFB < 0.3V Switch Saturation Voltage VCESAT 170 350 mV ♦ ISW = 250mA Switch Current Limit ILIM 250 350 450 mA ♦ SHDN Bias Current ISHDN 5 12 µA ♦ VSHDN = 3.3V SHDN High Threshold (on) VIH 0.9 V SHDN Low Threshold (off) VIL 0.25 V Switch Leakage Current ISWLK 0.01 5 µA ♦ Switch Off, VSW = 5V Date: 08/31/09 SP6690 Micro Power Boost Regulator, Series White LED Driver © Copyright 2005 Sipex Corporation 2
