Datasheet DMMT3906W (Diodes) - 2
Manufacturer | Diodes |
Description | 40V Matched Pair PNP Small Signal Transistor in SOT363 |
Pages / Page | 6 / 2 — DMMT3906W. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. … |
File Format / Size | PDF / 453 Kb |
DMMT3906W. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics – Total Device. ESD Ratings
DMMT3906W Absolute Maximum Ratings
(@TA = +25°C unless otherwise specified.)
Characteristic Symbol Value Unit
Collector-Base Voltage VCBO -40 V Collector-Emitter Voltage VCEO -40 V Emitter-Base Voltage VEBO -5.0 V Collector Current IC -200 mA
Power Dissipation (Note 7) Total Device PD 200 mW Thermal Resistance, Junction to Ambient (Note 7) RθJA 625 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
ESD Ratings
(Note 8)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 7. For a device mounted on minimum recommended pad layout with 1oz copper that is on a single-sided 1.6mm FR4 PCB; the device is measured under still air conditions whilst operating in a steady-state. 8. Refer to JEDEC specification JESD22-A114 and JESD22-A115.
DMMT3906W 2 of 6 February 2018 Document number: DS30312 Rev. 13 - 2
www.diodes.com
© Diodes Incorporated
