Catalog CR Magnetics Transducers, Relays, Transformers, Indicators (CR Magnetics) - 2
Manufacturer | CR Magnetics |
Description | Selection Guide |
Pages / Page | 38 / 2 — Specialist in Electrical. Current Monitoring. Selection Guide |
File Format / Size | PDF / 1.6 Mb |
link to page 3 link to page 4 link to page 5 link to page 6 link to page 7 link to page 9 link to page 9 link to page 11 link to page 15 link to page 17 link to page 18 link to page 19 link to page 21 link to page 23 link to page 26 link to page 27 link to page 32 link to page 33 link to page 35 link to page 37 link to page 38
Specialist in Electrical Current Monitoring Selection Guide
Transducers and Relays - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2 Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 3 Current Indicators and Voltage Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 4
Current Transformer Ratios - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 5 Transducers
AC Current to 0-5 / 10 Vdc - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 6 AC Current to 4-20 mA, 2-wire - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 8 AC Current to 4-20 mA, 4-wire - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -10 AC Voltage to 4-20 mA, 3-phase - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -12
Relays
AC Current Sensing Relay - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -14 Current Switch - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -16
Typical Relay Applications - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -17 Transformers
Wire Lead Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -18 Vertical Mounting, PCB Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - -20 Wire Lead Current Transformers, Series 8400 - - - - - - - - - - - - - - - - - - - - - - - - - - - -22 Horizontal Mounting, PCB Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - -25 Commercial and ANSI Metering Class Current Transformers - - - - - - - - - - - - - - - - - -26
3-Phase Balanced Networks - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -31 Indicators
Wire-Mounted Current Indicator - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -32 Remote Current Indicators - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -34 Low Cost Remote Current Indicators - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -36
AC Motor Loads & U.S. Standard Voltages - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -37 Custom Toroid and Bobbin Wound Transformers - - - - - - - - - - - - - - - - - - - - - - - - - -
Contact Factory
Excitation Curves
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Contact Factory
Other CR Magnetics Catalogs
3-Phase Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 3 Rectangular Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 4 Split-Core Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 5 Breaker Type Current Transformer - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 6 Wound Primary Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 7 Bushing Type Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 8 Ground Fault Sensors - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 9 Current & Voltage Transformers, IEC Rated, 50 Hz - - - - - - - - - - - - - - - - - - - - - - - -Section 10 Low Voltage, Voltage Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 11 Low Voltage, Control Power Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 12 Medium Voltage, Current Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 13 Medium Voltage, Current Transformers, IEC Rated, 50 Hz - - - - - - - - - - - - - - - - - - -Section 14 Medium Voltage, Voltage Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 15 Medium Voltage, Voltage Transformers, IEC Rated, 50 Hz - - - - - - - - - - - - - - - - - - -Section 16 Medium Voltage, Control Power Transformers - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 17 Ground Fault Systems - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 18 Instrumentation Switches - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Section 19 © 2000 CR Magnetics, Inc. — All rights reserved. 1
