Datasheet MC1488 (ON Semiconductor) - 10
Manufacturer | ON Semiconductor |
Description | Quad Line EIA-232D Driver |
Pages / Page | 14 / 10 — PDIP−14. DOCUMENT NUMBER: 98ASB42428B. DESCRIPTION:. PAGE 2 OF 2 |
Revision | 9 |
File Format / Size | PDF / 343 Kb |
PDIP−14
CASE 646−06 ISSUE S DATE 22 APR 2015 STYLE 1: STYLE 2: STYLE 3: STYLE 4: PIN 1. COLLECTOR CANCELLED CANCELLED PIN 1. DRAIN 2. BASE 2. SOURCE 3. EMITTER 3. GATE 4. NO 4. NO CONNECTION CONNECTION 5. EMITTER 5. GATE 6. BASE 6. SOURCE 7. COLLECTOR 7. DRAIN 8. COLLECTOR 8. DRAIN 9. BASE 9. SOURCE 10. EMITTER 10. GATE 11. NO 11. NO CONNECTION CONNECTION 12. EMITTER 12. GATE 13. BASE 13. SOURCE 14. COLLECTOR 14. DRAIN STYLE 5: STYLE 6: STYLE 7: STYLE 8: PIN 1. GATE PIN 1. COMMON CATHODE PIN 1. NO CONNECTION PIN 1. NO CONNECTION 2. DRAIN 2. ANODE/CATHODE 2. ANODE 2. CATHODE 3. SOURCE 3. ANODE/CATHODE 3. ANODE 3. CATHODE 4. NO CONNECTION 4. NO CONNECTION 4. NO CONNECTION 4. NO CONNECTION 5. SOURCE 5. ANODE/CATHODE 5. ANODE 5. CATHODE 6. DRAIN 6. NO CONNECTION 6. NO CONNECTION 6. NO CONNECTION 7. GATE 7. ANODE/CATHODE 7. ANODE 7. CATHODE 8. GATE 8. ANODE/CATHODE 8. ANODE 8. CATHODE 9. DRAIN 9. ANODE/CATHODE 9. ANODE 9. CATHODE 10. SOURCE 10. NO CONNECTION 10. NO CONNECTION 10. NO CONNECTION 11. NO CONNECTION 11. ANODE/CATHODE 11. ANODE 11. CATHODE 12. SOURCE 12. ANODE/CATHODE 12. ANODE 12. CATHODE 13. DRAIN 13. NO CONNECTION 13. NO CONNECTION 13. NO CONNECTION 14. GATE 14. COMMON ANODE 14. COMMON 14. COMMON ANODE CATHODE STYLE 9: STYLE 10: STYLE 11: STYLE 12: PIN 1. COMMON CATHODE PIN 1. COMMON PIN 1. CATHODE PIN 1. COMMON CATHODE 2. ANODE/CATHODE CATHODE 2. CATHODE 2. COMMON ANODE 3. ANODE/CATHODE 2. ANODE/CATHODE 3. CATHODE 3. ANODE/CATHODE 4. NO CONNECTION 3. ANODE/CATHODE 4. CATHODE 4. ANODE/CATHODE 5. ANODE/CATHODE 4. ANODE/CATHODE 5. CATHODE 5. ANODE/CATHODE 6. ANODE/CATHODE 5. ANODE/CATHODE 6. CATHODE 6. COMMON ANODE 7. COMMON ANODE 6. NO CONNECTION 7. CATHODE 7. COMMON CATHODE 8. COMMON ANODE 7. COMMON ANODE 8. ANODE 8. ANODE/CATHODE 9. ANODE/CATHODE 8. COMMON 9. ANODE 9. ANODE/CATHODE 10. ANODE/CATHODE CATHODE 10. ANODE 10. ANODE/CATHODE 11. NO CONNECTION 9. ANODE/CATHODE 11. ANODE 11. ANODE/CATHODE 12. ANODE/CATHODE 10. ANODE/CATHODE 12. ANODE 12. ANODE/CATHODE 13. ANODE/CATHODE 11. ANODE/CATHODE 13. ANODE 13. ANODE/CATHODE 14. COMMON CATHODE 12. ANODE/CATHODE 14. ANODE 14. ANODE/CATHODE 13. NO CONNECTION 14. COMMON ANODE
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: PDIP−14 PAGE 2 OF 2
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
