Datasheet SMAJ (Littelfuse) - 2
Manufacturer | Littelfuse |
Description | TVS Diodes Surface Mount – 400W |
Pages / Page | 6 / 2 — TVS Diodes. Electrical Characteristics (T =25°C unless otherwise noted). … |
File Format / Size | PDF / 1.0 Mb |
TVS Diodes. Electrical Characteristics (T =25°C unless otherwise noted). Reverse. Breakdown. Maximum Maximum Maximum. Agency. Part
TVS Diodes
Surface Mount – 400W > SMAJ series
Electrical Characteristics (T =25°C unless otherwise noted) A Reverse Breakdown Maximum Maximum Maximum Agency Part Part Test Marking Stand off Voltage V Clamping Peak Pulse Reverse Approval Number Number BR Current Voltage V Voltage V Current I Leakage I @ (Uni) (Bi) (Volts) @ I R T C pp R (Volts) I (mA) T @ I (V) (A) V (µA) Uni. Bi. Min. Max. pp R
SMAJ5.0A SMAJ5.0CA AE WE 5.0 6.40 7.00 10 9.2 43.5 800 X SMAJ6.0A SMAJ6.0CA AG WG 6.0 6.67 7.37 10 10.3 38.8 800 X SMAJ6.5A SMAJ6.5CA AK WK 6.5 7.22 7.98 10 11.2 35.7 500 X SMAJ7.0A SMAJ7.0CA AM WM 7.0 7.78 8.60 10 12.0 33.3 200 X SMAJ7.5A SMAJ7.5CA AP WP 7.5 8.33 9.21 1 12.9 31.0 100 X SMAJ8.0A SMAJ8.0CA AR WR 8.0 8.89 9.83 1 13.6 29.4 50 X SMAJ8.5A SMAJ8.5CA AT WT 8.5 9.44 10.40 1 14.4 27.8 20 X SMAJ9.0A SMAJ9.0CA AV WV 9.0 10.00 11.10 1 15.4 26.0 10 X SMAJ10A SMAJ10CA AX WX 10.0 11.10 12.30 1 17.0 23.5 5 X SMAJ11A SMAJ11CA AZ WZ 11.0 12.20 13.50 1 18.2 22.0 1 X SMAJ12A SMAJ12CA BE XE 12.0 13.30 14.70 1 19.9 20.1 1 X SMAJ13A SMAJ13CA BG XG 13.0 14.40 15.90 1 21.5 18.6 1 X SMAJ14A SMAJ14CA BK XK 14.0 15.60 17.20 1 23.2 17.2 1 X SMAJ15A SMAJ15CA BM XM 15.0 16.70 18.50 1 24.4 16.4 1 X SMAJ16A SMAJ16CA BP XP 16.0 17.80 19.70 1 26.0 15.4 1 X SMAJ17A SMAJ17CA BR XR 17.0 18.90 20.90 1 27.6 14.5 1 X SMAJ18A SMAJ18CA BT XT 18.0 20.00 22.10 1 29.2 13.7 1 X SMAJ20A SMAJ20CA BV XV 20.0 22.20 24.50 1 32.4 12.3 1 X SMAJ22A SMAJ22CA BX XX 22.0 24.40 26.90 1 35.5 11.3 1 X SMAJ24A SMAJ24CA BZ XZ 24.0 26.70 29.50 1 38.9 10.3 1 X SMAJ26A SMAJ26CA CE YE 26.0 28.90 31.90 1 42.1 9.5 1 X SMAJ28A SMAJ28CA CG YG 28.0 31.10 34.40 1 45.4 8.8 1 X SMAJ30A SMAJ30CA CK YK 30.0 33.30 36.80 1 48.4 8.3 1 X SMAJ33A SMAJ33CA CM YM 33.0 36.70 40.60 1 53.3 7.5 1 X SMAJ36A SMAJ36CA CP YP 36.0 40.00 44.20 1 58.1 6.9 1 X SMAJ40A SMAJ40CA CR YR 40.0 44.40 49.10 1 64.5 6.2 1 X SMAJ43A SMAJ43CA CT YT 43.0 47.80 52.80 1 69.4 5.8 1 X SMAJ45A SMAJ45CA CV YV 45.0 50.00 55.30 1 72.7 5.5 1 X SMAJ48A SMAJ48CA CX YX 48.0 53.30 58.90 1 77.4 5.2 1 X SMAJ51A SMAJ51CA CZ YZ 51.0 56.70 62.70 1 82.4 4.9 1 X SMAJ54A SMAJ54CA RE ZE 54.0 60.00 66.30 1 87.1 4.6 1 X SMAJ58A SMAJ58CA RG ZG 58.0 64.40 71.20 1 93.6 4.3 1 X SMAJ60A SMAJ60CA RK ZK 60.0 66.70 73.70 1 96.8 4.1 1 X SMAJ64A SMAJ64CA RM ZM 64.0 71.10 78.60 1 103.0 3.9 1 X SMAJ70A SMAJ70CA RP ZP 70.0 77.80 86.00 1 113.0 3.5 1 X SMAJ75A SMAJ75CA RR ZR 75.0 83.30 92.10 1 121.0 3.3 1 X SMAJ78A SMAJ78CA RT ZT 78.0 86.70 95.80 1 126.0 3.2 1 X SMAJ85A SMAJ85CA RV ZV 85.0 94.40 104.00 1 137.0 2.9 1 X SMAJ90A SMAJ90CA RX ZX 90.0 100.00 111.00 1 146.0 2.7 1 X SMAJ100A SMAJ100CA RZ ZZ 100.0 111.00 123.00 1 162.0 2.5 1 X SMAJ110A SMAJ110CA SE VE 110.0 122.00 135.00 1 177.0 2.3 1 X SMAJ120A SMAJ120CA SG VG 120.0 133.00 147.00 1 193.0 2.1 1 X SMAJ130A SMAJ130CA SK VK 130.0 144.00 159.00 1 209.0 1.9 1 X SMAJ150A SMAJ150CA SM VM 150.0 167.00 185.00 1 243.0 1.6 1 X SMAJ160A SMAJ160CA SP VP 160.0 178.00 197.00 1 259.0 1.5 1 X SMAJ170A SMAJ170CA SR VR 170.0 189.00 209.00 1 275.0 1.5 1 X SMAJ180A SMAJ180CA ST VT 180.0 201.00 222.00 1 292.0 1.4 1 - SMAJ188A SMAJ188CA SB VB 188.0 209.00 231.00 1 304.0 1.4 1 - SMAJ200A SMAJ200CA SV VV 200.0 224.00 247.00 1 324.0 1.2 1 - SMAJ220A - SX - 220.0 246.00 272.00 1 356.0 1.1 1 - - SMAJ220CA* - VX 220.0 246.00 272.00 1 356.0 1.7 1 - SMAJ250A - SZ - 250.0 279.00 309.00 1 405.0 1.0 1 - - SMAJ250CA* - VZ 250.0 279.00 309.00 1 405.0 1.5 1 - SMAJ300A* SMAJ300CA* TE UE 300.0 335.00 371.00 1 486.0 1.3 1 - SMAJ350A* SMAJ350CA* TG UG 350.0 391.00 432.00 1 567.0 1.1 1 - SMAJ400A* SMAJ400CA* TK UK 400.0 447.00 494.00 1 648.0 1.0 1 - SMAJ440A* SMAJ440CA* TM UM 440.0 492.00 543.00 1 713.0 0.9 1 -
Notes:
For bidirectional type having V of 10 volts and less, the I limit is double. R R For stack-die parts, use
to label the part number. © 2020 Littelfuse, Inc. Specifications are subject to change without notice. Revised: BA.10/21/20
