Datasheet SiHH070N60EF (Vishay) - 7
ManufacturerVishay
DescriptionEF Series Power MOSFET With Fast Body Diode
Pages / Page9 / 7 — Package Information. PowerPAK® 8 x 8 Case Outline. MILLIMETERS. INCHES. …
File Format / SizePDF / 184 Kb
Package Information. PowerPAK® 8 x 8 Case Outline. MILLIMETERS. INCHES. DIM. MIN. NOM. MAX. Notes
Package Information PowerPAK® 8 x 8 Case Outline MILLIMETERS INCHES DIM MIN NOM MAX Notes
Package Information
D2 D3 2x D 0.1 C A E3 A 2x 0.1 C B PPAK 8 x 8 (8 mm x 8 mm) E2 E K B L e b Pin 1 dot 5, 6 TOP SIDE VIEW by marking BACK SIDE VIEW A C A1 A2 0.08
MILLIMETERS INCHES DIM. MIN. NOM. MAX. MIN. NOM. MAX.
A 0.95 1.00 1.05 0.037 0.039 0.041 A1 0.00 - 0.05 0.000 - 0.002 A2 020 ref. 0.008 ref. b 0.95 1.00 1.05 0.037 0.039 0.041 D 7.90 8.00 8.10 0.311 0.315 0.319 D2 7.10 7.20 7.30 0.280 0.283 0.287 D3 0.40 BSC 0.016 BSC e 2.00 BSC 0.079 BSC E 7.90 8.00 8.10 0.311 0.315 0.319 E2 4.30 4.35 4.40 0.169 0.171 0.173 E3 0.40 BSC 0.016 BSC K 2.75 BSC 0.108 BSC L 0.45 0.50 0.55 0.018 0.020 0.022 N (3) 8 8
Notes
(1) Use millimeters as the primary measurement (2) Dimensioning and tolerances conform to ASME Y14.5 M - 1994 (3) N is the number of terminals (4) The pin 1 identifier must be existed on the top surface of the package by using indentation mark or other feature of package body (5) Exact shape and size of this feature is optional ECN: E20-0518-Rev. B, 28-Sep-2020 DWG: 6041 Revision: 28-Sep-2020
1
Document Number: 67859 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
