Datasheet H11AV1, H11AV1A, H11AV2, H11AV2A (Fairchild) - 5
ManufacturerFairchild
Description6-Pin DIP Optoisolators Transistor Output
Pages / Page7 / 5 — H11AV1,A H11AV2,A. PACKAGE DIMENSIONS. –A–. –B–. INCHES. MILLIMETERS. …
File Format / SizePDF / 154 Kb
H11AV1,A H11AV2,A. PACKAGE DIMENSIONS. –A–. –B–. INCHES. MILLIMETERS. DIM. MIN. MAX. 4 PL. –T–. SEATING. PLANE. J 6 PL. 6 PL. D 6 PL. THRU HOLE
H11AV1,A H11AV2,A PACKAGE DIMENSIONS –A– –B– INCHES MILLIMETERS DIM MIN MAX 4 PL –T– SEATING PLANE J 6 PL 6 PL D 6 PL THRU HOLE
NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI
6 4
Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH.
–B–
3. DIMENSION L TO CENTER OF LEAD WHEN
1 3
FORMED PARALLEL.
INCHES MILLIMETERS DIM MIN MAX MIN MAX F C 4 PL N L A
0.320 0.350 8.13 8.89
B
0.240 0.260 6.10 6.60
C
0.115 0.200 2.93 5.08
D
0.016 0.020 0.41 0.50
E
0.040 0.070 1.02 1.77
F
0.010 0.014 0.25 0.36
–T– K G
0.100 BSC 2.54 BSC
SEATING J
0.008 0.012 0.21 0.30
PLANE K
0.100 0.150 2.54 3.81
G J 6 PL L
0.300 BSC 7.62 BSC 0.13 (0.005) M T B M A M
E M M
0 15 0 15
6 PL
_ _ _ _
N
0.015 0.100 0.38 2.54
D 6 PL
0.13 (0.005) M T A M B M STYLE 1: PIN 1. ANODE 2. CATHODE 3. NC 4. EMITTER 5. COLLECTOR 6. BASE
THRU HOLE –A– 6 4 –B–
S NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI
1 3
INCHES MILLIMETERS F DIM MIN MAX MIN MAX 4 PL L H A
B
C
C D
E
–T– F
G J G
0.100 BSC 2.54 BSC
SEATING PLANE H
0.020 0.025 0.51 0.63
K 6 PL E 6 PL J
0.008 0.012 0.20 0.30
K
0.006 0.035 0.16 0.88
D 6 PL
L
0.320 BSC 8.13 BSC
S
0.332 0.390 8.43 9.90 0.13 (0.005) M T A M B M
SURFACE MOUNT
