Datasheet IM828-XCC (Infineon)
ManufacturerInfineon
DescriptionCIPOS Maxi IM828. The CIPOS Maxi IM828 product group offers the chance for integrating various power and control components to increase reliability, optimize PCB size and system costs.
Pages / Page23 / 1 — IM828-XCC Datasheet. CIPOS™ Maxi IM828 IM828-XCC. Description. Features. …
Revision02_00
IM828-XCC Datasheet. CIPOS™ Maxi IM828 IM828-XCC. Description. Features. Potential applications. Product validation. Table 1
Datasheet IM828-XCC Infineon, Revision: 02_00
IM828-XCC Datasheet CIPOS™ Maxi IM828 IM828-XCC Description
The CIPOS™ Maxi IM828 product group offers the chance for integrating various power and control components to increase reliability, optimize PCB size and system costs. It is designed to operate as high performance inverter for demanding motor drive applications and active power factor correction. The product concept is specially adapted to power applications, which need good thermal performance and electrical isolation as well as EMI save control and overload protection.Three phase inverter with 1200V CoolSiC™ MOSFETs are combined with an optimized 6-channel SOI gate driver for excellent electrical performance. The bodydiodes of CoolSiC™ MOSFETs can be used as free-wheeling diode, and turning on the MOSFET during bodydiode conduction (synchronous rectification) can be used to reduce losses further.
Features
Fully isolated Dual In-Line molded module 1200V CoolSiC™ MOSFETs Rugged 1200V SOI gate driver technology with stability against transient and negative voltage Allowable negative VS potential up to -11 V for signal transmission at VBS = 15 V Integrated bootstrap functionality Over current shutdown Built-in NTC thermistor for temperature monitor Under-voltage lockout at all channels Low side source pins accessible for all phase current monitoring (open source) Cross-conduction prevention All of 6 switches turn off during protection Programmable fault clear timing and enable input Lead-free terminal plating; RoHS compliant
Fan drives and active power factor correction and high performance motor drives
Product validation
Qualified for industrial applications according to the relevant tests of JEDEC47/20/22.
Table 1 Part Ordering Table Standard pack Product name Package type Orderable part number Form MOQ
IM828-XCC DIP 36x23D 14 pcs / tube 280 IM828XCCXKMA1 Datasheet Please read the Important Notice and Warnings at the end of this document V 2.0
www.infineon.com
page 1 of 23 2020-09-03
