Datasheet 1ED34x1Mc12M (1ED-X3 Analog) (Infineon)
ManufacturerInfineon
DescriptionEiceDRIVER/ 1ED34x1Mc12M Enhanced. Single-channel isolated gate driver IC with adjustable DESAT and soft-off
Pages / Page45 / 1 — 1ED34x1Mc12M (1ED-X3 Analog). EiceDRIVER™ 1ED34x1Mc12M Enhanced Datasheet
Revision02_00
File Format / SizePDF / 733 Kb
Datasheet 1ED34x1Mc12M (1ED-X3 Analog) Infineon, Revision: 02_00
1ED34x1Mc12M (1ED-X3 Analog) EiceDRIVER™ 1ED34x1Mc12M Enhanced Datasheet Single-channel isolated gate driver IC with adjustable DESAT and soft-off Features
• 600 V, 650 V, 900 V, and 1200 V IGBTs, SiC and Si MOSFETs • 40 V absolute maximum output supply voltage • ±3 A, ±6 A, and ±9 A typical sinking and sourcing peak output current • Separate source and sink outputs and active Miller clamp/clamp driver • Adjustment pins for parameter configuration from input side • Precise VCEsat detection (DESAT) with fault output and adjustable filter time and leading edge blanking time with resistor at ADJB pin • Adjustable IGBT soft turn-off after desaturation detection with resistor at ADJA pin • Operation at high ambient temperature up to 125 °C with over-temperature shut down at 160 °C (±10 °C) • Tight IC-to-IC propagation delay matching (tPDD,max = 30 ns) • Undervoltage lockout protection with hysteresis for input and output side with active shut-down • High common-mode transient immunity CMTI = 200 kV/µs • Small space-saving DSO-16 fine-pitch package with large creepage distance (>8 mm) • Safety certification - UL 1577 recognized (planned) with VISO,test = 6840 V (rms) for 1 s, VISO = 5700 V (rms) for 60 s - IEC 60747-17/VDE 0884-11 approval (planned) with VIORM = 1.4 kV (peak, reinforced) • Evaluation board available
EVAL-1ED3491MX12M Potential applications
• Industrial motor drives - compact, standard, premium, servo drives • Solar inverters • UPS systems • Welding • Commercial and agricultural vehicles (CAV) • Commercial air-conditioning (CAC) PG-DSO-16 • High-voltage isolated DC-DC converters • Isolated switch mode power supplies (SMPS)
Product validation
Qualified for industrial applications according to the relevant tests of JEDEC47/20/22. Datasheet Please read the Important Notice and Warnings at the end of this document v2.0
www.infineon.com/gdisolated
2020-03-26 Document Outline Table of contents 1 Block diagram 2 Related products 3 Pin configuration and functionality 3.1 Pin configuration 3.2 Pin functionality 4 Functional description 4.1 Start-up and fault clearing 4.2 Supply 4.2.1 Input side undervoltage lockout, VCC1 UVLO 4.2.2 Output side under-voltage lockout, VCC2 UVLO 4.3 Input side logic 4.3.1 IN non-inverting driver input 4.3.2 RDYC ready status output, fault-off and fault clear input 4.3.2.1 RDYC fault-off input 4.3.2.2 RDYC fault clear input 4.3.3 FLT_N status output and fault-off input 4.3.3.1 FLT_N fault-off input 4.4 Desaturation protection 4.4.1 DESAT behavior 4.4.2 DESAT filter and leading edge blanking time adjustment with ADJB 4.5 Gate driver output 4.5.1 Turn-on behavior 4.5.2 Turn-off and fault turn-off behavior 4.5.2.1 Hard switching turn-off 4.5.2.2 Soft turn-off 4.5.2.2.1 Soft-off current source adjustment with ADJA 4.5.3 Active shut-down 4.5.4 Active Miller clamp 4.5.4.1 CLAMP output types 4.5.5 Switch-off timeout until forced switch-off 4.6 Short circuit clamping 5 Electrical parameters 5.1 Absolute maximum ratings 5.2 Thermal parameters 5.3 Operating parameters 5.4 Electrical characteristics 5.4.1 Voltage supply 5.4.2 Logic input and output 5.4.3 Analog input 5.4.4 Gate driver 5.4.5 Active Miller clamp 5.4.6 Dynamic characteristics 5.4.7 Desaturation protection 5.4.8 Soft-off current source 5.4.9 Over-temperature protection 6 Insulation characteristics 6.1 Certified according to VDE 0884-11 and IEC 60747-17 reinforced insulation (planned) 6.2 Recognized under UL 1577 (planned) 6.3 Reliability 7 Package information 8 Application notes 8.1 Reference layout for thermal data 8.2 Printed circuit board guidelines Revision history Disclaimer
