Preliminary Datasheet QPC1252Q (Qorvo) - 4
ManufacturerQorvo
DescriptionBroadband High Linearity DSDA e-Call Antenna Routing Switch
Pages / Page17 / 4 — PRELIMINARY. QPC1252Q. BROADBAND HIGH LINEARITY DSDA e-CALL ANTENNA …
File Format / SizePDF / 976 Kb
PRELIMINARY. QPC1252Q. BROADBAND HIGH LINEARITY DSDA e-CALL ANTENNA ROUTING SWITCH. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS
PRELIMINARY QPC1252Q BROADBAND HIGH LINEARITY DSDA e-CALL ANTENNA ROUTING SWITCH PARAMETER CONDITIONS MIN TYP MAX UNITS
PRELIMINARY QPC1252Q BROADBAND HIGH LINEARITY DSDA e-CALL ANTENNA ROUTING SWITCH PARAMETER CONDITIONS MIN. TYP. MAX. UNITS Isolation Any Active Switch Path
Any Active Port 617 MHz to 960 MHz TBD 30 dB to any other 1427 MHz to 2690 MHz TBD 25 dB Active Port 3300 MHz to 6000 MHz TBD 20 dB
PARAMETER CONDITIONS MIN. TYP. MAX. UNITS Harmonics Any Active Switch Path
2nd Harmonic -80 TBD dBc Freq = 915 MHz; PIN = 36 dBm 3rd Harmonic -70 TBD dBc 2nd Harmonic -80 TBD dBc Freq = 1980 MHz; PIN = 33 dBm 3rd Harmonic -75 TBD dBc
PARAMETER CONDITIONS MIN. TYP. MAX. UNITS Intermodulation Any Active Switch Path
INPUT IP2 Freq = 617 MHz to 960 MHz; 110 dBm INPUT IP3 PIN = 20 dBm/tone, 30MHz spacing 60 dBm INPUT IP2 Freq = 1427 MHz to 6000 MHz; 110 dBm INPUT IP3 PIN = 20 dBm/tone, 30MHz spacing 60 dBm
617 MHz to 960 MHz 15 dB
Return Loss – Switch Path
1427 MHz to 2700 MHz 14 dB
(RF1,2,3,6)
3300 MHz to 6000 MHz 12 dB
Return Loss – Divider Path
617 MHz to 960 MHz 10 dB
(RF4,5)
1427 MHz to 2700 MHz 14 dB 1) Recommended EVB schematic/layout/BOM/PCB to be followed in order to achieve specified performance. Switch Path is RF1,2,3,6 Divider Path is RF4,5 QPC1252Q Preliminary DS RevA | Subject to change without notice 4 of 17
www.qorvo.com
