Datasheet BYV28-50, BYV28-100, BYV28-150, BYV28-200 (Vishay) - 2
ManufacturerVishay
DescriptionUltra-Fast Avalanche Sinterglass Diode
Pages / Page4 / 2 — BYV28-50, BYV28-100, BYV28-150, BYV28-200. MAXIMUM THERMAL RESISTANCE. …
File Format / SizePDF / 123 Kb
BYV28-50, BYV28-100, BYV28-150, BYV28-200. MAXIMUM THERMAL RESISTANCE. PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT
BYV28-50, BYV28-100, BYV28-150, BYV28-200 MAXIMUM THERMAL RESISTANCE PARAMETER TEST CONDITION SYMBOL VALUE UNIT
(Tamb = 25 °C, unless otherwise specified)
Lead length l = 10 mm, TL = constant RthJA 25 K/W Junction ambient On PC board with spacing 25 mm RthJA 70 K/W
ELECTRICAL CHARACTERISTICS
PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT
IF = 5 A VF - - 1.1 V Forward voltage IF = 5 A, Tj = 175 °C VF - - 0.89 V VR = VRRM IR - - 1 μA Reverse current VRSM IR - - 100 μA VR = VRRM, Tj = 165 °C IR - - 150 μA Reverse recovery time IF = 0.5 A, IR = 1 A, iR = 0.25 A trr - - 30 ns
TYPICAL CHARACTERISTICS
(Tamb = 25 C, unless otherwise specified) 40 4.0 V = V R RRM 3.5 half sine wave R ≤ 25 K/W 30 thJA 3.0 l = 10 mm 2.5 20 l l 2.0 t. Junction/Ambient (K/W) 1.5 is s 10 1.0 R ≤ 70 K/W thJA - Average Forward Current (A) PCB: d = 25 mm 0.5 T = constant L I FAV - Ther. Re 0 0.0 0 5 10 15 20 25 30 0 20 40 60 80 100 120 140 160 180 thJAR 949548 l - Lead Length (mm) 16454 Tamb - Ambient Temperature (°C) Fig. 1 - Max. Thermal Resistance vs. Lead Length Fig. 3 - Max. Average Forward Current vs. Ambient Temperature 100 1000 V = V R RRM 10 T = 175 °C j 100 1 T = 25 °C e Current (A) j s 0.1 10 - Forward Current (A) - Rever I F 0.01 I R 0.001 1 0.0 0.4 0.8 1.2 1.6 2.0 25 50 75 100 125 150 175 16453 V 16455 F - Forward Voltage (V) Tj - Junction Temperature (°C) Fig. 2 - Forward Current vs. Forward Voltage Fig. 4 - Reverse Current vs. Junction Temperature Rev. 1.9. 21-Feb-18
2
Document Number: 86044 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
