Datasheet 18650HG2 (LG) - 10
ManufacturerLG
DescriptionRechargeable Lithium Ion Battery 3000 mAh
Pages / Page12 / 10 — PRODUCT SPECIFICATION. Description. Document No. Date. Rev
File Format / SizePDF / 447 Kb
PRODUCT SPECIFICATION Description Document No Date Rev
PRODUCT SPECIFICATION Description Document No. Date Rev
Lithium Ion LG 18650 HG2 3000mAh PS-HG2-Rev5 2017-03-31 5  The cells should be sold only to Battery Pack Maker(s) or System Integrator(s). The cells should not be handled by individual consumers and should not be sold to individual consumers by individual markets. (especially, the cells are strictly prohibited to be used for any kinds of E-cigarette devices)  Be sure to request and confirm the most current product specifications in advance which explain the specifications in detail, before the final stage of your design, purchasing or use for any application. 5.2 Prohibitions  Do not use different charger. Do not use cigarette jacks (in cars) for charging.  Do not charge with constant current more than maximum charge current.  Do not disassemble or reconstruct the battery.  Do not throw or cause impact.  Do not pierce a hole in the battery with sharp things. (such as nail, knife, pencil, drill)  Do not use with other batteries or cells.  Do not solder on battery directly.  Do not press the battery with overload in manufacturing process, especially ultrasonic welding.  Do not use old and new cells together for packing.  Do not expose the battery to high heat. (such as fire)  Do not put the battery into a microwave or high pressure container.  Do not use the battery reversed.  Do not connect positive(+) and negative(-) with conductive materials (such as metal, wire)  Do not allow the battery to be immerged in or wetted with water or sea-water.  Do not give immoderate heat and force to battery cell during a welding process of metal plates on it. 5.3 Caution for the battery and the pack Pack shall meet under condition to maintain battery safety and last long performance of the lithium rechargeable cells. 5.3.1 Installing the battery into the pack -. The cell should be inspected visually before battery assembly into the pack. -. Damaged cell should not be used. (damaged surface, can-distortion, electrolyte-smell) -. Different Lot Number cells should not be packaged into the same pack. -. Different types of cells, or same types but different cell maker’s should not be used together. 5.3.2 Design of battery pack -. The battery pack should not be connected easily to any charger other than the dedicated charger. -. The battery pack has function not to cause external short cut easily. -.The design of battery pack and its structure should be reviewed physically, mechanically and electrically not to cause cell imbalance. 10/12
