LTC1694 WWWUUWUABSOLUTE AXI U RATI GSPACKAGE/ORDER I FOR ATIO(Note 1) ORDER PART Supply Voltage (VCC) ... 7V TOP VIEW NUMBER SMBus1, SMBus2 Inputs .. – 0.3V to (VCC + 0.3V) Operating Ambient Temperature Range VCC 1 5 SMBus1 LTC1694CS5 LTC1694C ... 0°C to 70°C GND 2 LTC1694IS5 LTC1694I .. – 40°C to 85°C NC 3 4 SMBus2 Junction Temperature ... 125°C S5 PACKAGE S5 PART MARKING 5-LEAD PLASTIC TSOT-23 Storage Temperature Range ... – 65°C to 150°C TJMAX = 125°C, θJA = 256°C/ W LTEE Lead Temperature (Soldering, 10 sec).. 300°C LTA8 Consult LTC Marketing for parts specified with wider operating temperature ranges. ELECTRICAL CHARACTERISTICS The ● denotes specifications that apply over the full operating temperature range, otherwise specifications are at TA = 25 ° C.VCC = 2.7V to 6V unless otherwise noted.SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS VCC Supply Voltage Range 2.7 6 V ICC Supply Current SMBus1 = SMBus2 = Open ● 20 60 100 µA IPULL-UP Pull-Up Current SMBus1 = SMBus2 = 0V ● 125 275 350 µA Boosted Pull-Up Current Positive Transition on SMBus ( Figure 1) ● 1.0 2.2 mA Slew Rate = 0.5V/µs, SMBus > VTHRES VTHRES Input Threshold Voltage Slew Rate = 0.5V/µs (Figure 1) ● 0.4 0.65 0.9 V SRTHRES Slew Rate Detector Threshold SMBus > VTHRES ● 0.2 0.5 V/µs tr SMBus Rise Time Bus Capacitance = 200pF (Note 2) ● 0.32 1.0 µs Standard Mode I2C Bus Rise Time Bus Capacitance = 400pF (Note 3) ● 0.30 1.0 µs fMAX SMBus Maximum Operating Frequency (Note 4) ● 100 kHz Note 1: Absolute Maximum Ratings are those values beyond which the life Note 3: The rise time of an I2C bus line is calculated from VIL(MAX) to of a device may be impaired. VIH(MIN) or 1.5V to 3V (with VCC = 5V). This parameter is guaranteed by Note 2: The rise time of an SMBus line is calculated from (V design and not tested. With a minimum boosted pull-up current of 1mA: IL(MAX) – 0.15V) to (VIH(MIN) + 0.15V) or 0.65V to 2.25V. This parameter is Rise Time = (3V – 1.5V) • 400pF/1mA = 0.6µs guaranteed by design and not tested. With a minimum pull-up current of Note 4: This parameter is guaranteed by design and not tested. 125µA, a minimum boosted pull-up current of 1mA and a maximum input threshold voltage of 0.9V: Rise Time = [(0.9V – 0.65V)/125µA + (2.25V – 0.9V)/1mA] • 200pF = 0.67µs 1694fa 2
