Datasheet MTP2P50EG (ON Semiconductor) - 7
Manufacturer | ON Semiconductor |
Description | Power MOSFET 2 Amps, 500 Volts, P−Channel TO−220 |
Pages / Page | 8 / 7 — PACKAGE DIMENSIONS. TO−220. SCALE 1:1. DOCUMENT NUMBER: 98ASB42148B. … |
Revision | 7 |
File Format / Size | PDF / 241 Kb |
PACKAGE DIMENSIONS. TO−220. SCALE 1:1. DOCUMENT NUMBER: 98ASB42148B. DESCRIPTION:. PAGE 1 OF 1
MECHANICAL CASE OUTLINE
PACKAGE DIMENSIONS TO−220
CASE 221A−09 ISSUE AJ DATE 05 NOV 2019
SCALE 1:1
STYLE 1: STYLE 2: STYLE 3: STYLE 4: PIN 1. BASE PIN 1. BASE PIN 1. CATHODE PIN 1. MAIN TERMINAL 1 2. COLLECTOR 2. EMITTER 2. ANODE 2. MAIN TERMINAL 2 3. EMITTER 3. COLLECTOR 3. GATE 3. GATE 4. COLLECTOR 4. EMITTER 4. ANODE 4. MAIN TERMINAL 2 STYLE 5: STYLE 6: STYLE 7: STYLE 8: PIN 1. GATE PIN 1. ANODE PIN 1. CATHODE PIN 1. CATHODE 2. DRAIN 2. CATHODE 2. ANODE 2. ANODE 3. SOURCE 3. ANODE 3. CATHODE 3. EXTERNAL TRIP/DELAY 4. DRAIN 4. CATHODE 4. ANODE 4. ANODE STYLE 9: STYLE 10: STYLE 11: STYLE 12: PIN 1. GATE PIN 1. GATE PIN 1. DRAIN PIN 1. MAIN TERMINAL 1 2. COLLECTOR 2. SOURCE 2. SOURCE 2. MAIN TERMINAL 2 3. EMITTER 3. DRAIN 3. GATE 3. GATE 4. COLLECTOR 4. SOURCE 4. SOURCE 4. NOT CONNECTED
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TO−220 PAGE 1 OF 1
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com
