Datasheet 2SA1540, 2SC3955 (Sanyo)
ManufacturerSanyo
DescriptionHigh-Definition CRT Display Video Output Applications
Pages / Page4 / 1 — Ordering number:ENN2439B. 2SA1540/2SC3955. High-Definition CRT Display. …
File Format / SizePDF / 42 Kb
Ordering number:ENN2439B. 2SA1540/2SC3955. High-Definition CRT Display. Video Output Applications. Applications
Datasheet 2SA1540, 2SC3955 Sanyo
PNP/NPN Epitaxial Planar Silicon Transistors
2SA1540/2SC3955 High-Definition CRT Display Video Output Applications Applications Package Dimensions
· High-definition CRT display video output, wide-band unit:mm amplifier. 2042B [2SA1540/2SC3955]
Features
8.0 4.0 · High gain-bandwidth product : f 3.3 T=300MHz. 1.0 1.0 1.4 · High breakdown voltage : VCEO=200Vmin. · Small reverse transfer capacitance and excellent high 3.0 11.0 frequency characteristics : C 7.5 re=1.5pF/NPN, 1.8pF/ 1.5 PNP. 1.6 0.8 · Complementary PNP and NPN types. 3.0 · Adoption of FBET process. 0.8 15.5 · Micaless type : TO-126 plastic package. 0.75 0.7 1 2 3 1 : Emitter 2 : Collector ( ) : 2SA1540 2.4 1.7 4.8 3 : Base
Specifications
SANYO : TO-126ML
Absolute Maximum Ratings
at Ta = 25˚C m a r a P r e t e y S o b m l d n o C i o i t s n a R g n i t s U t i n o C ll e s a B - o t - r o t c e t l o V e g a V O B C 0 0 2 ) – ( V l o C o t c e l r e t t i m E - o t - r e g a t l o V VC O E 2 ) – ( 0 0 V i m E r e t t s a B - o t - e V e g a t l o VE O B 3 ) – ( V o C c e ll o t r C t n e r r u IC 0 1 ) – ( 0 A m e P ak r o t c e ll o C C t n e r r u I P C 0 0 2 ) – ( A m 3 . 1 W o C ll r o t c e s i D n o i t a p i s PC Tc=25˚C 7 W Ju c n o i t n T e r u t a r e p m e j T 1 0 5 ˚C r o t S g a e m e T e r u t a r e p s T g t 5 5 – o t 0 5 1 + ˚C
Electrical Characteristics
at Ta = 25˚C t a R s g n i m a r a P r e t e y S o b m l t i d n o C n o i s n U t i n i m p y t x a m o C l o t c e l r f f o t u C C t n e r r u I B C O VCB ( = V 0 5 1 ) – , IE 0 = 0 ) – ( 1 . A µ r e t t i m E f f o t u C C r u t n e r I O B E V B E = ) – ( V 2 , IC 0 = . 1 ) – ( 0 µA h E F 1 V E C = ) – ( 0 1 , V IC= ) – ( 0 1 A m 0 4 * 2 3 0* C D Cu t n e r r G n i a h E F 2 V E C ( = , V 0 1 ) – IC ( = A m 0 5 ) – 0 2 G i a n a B - n h t d i w d P t c u d o r fT V E C ( = , V 0 3 ) – IC ( = A m 0 3 ) – 0 3 0 z H M *hFE1 : The 2SA1540/2SC3955 are classified by 10mA hFE as follows : Continued on next page. n a R k C D E F h E F 0 4 o t 80 0 6 to 0 2 1 1 0 0 to 0 0 2 1 0 6 o t 0 2 3 Any and all SANYO products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft’s control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your SANYO representative nearest you before using any SANYO products described or contained herein in such applications. SANYO assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges,or other parameters) listed in products specifications of any and all SANYO products described or contained herein.
SANYO Electric Co.,Ltd. Semiconductor Company
TOKYO OFFICE Tokyo Bldg., 1-10, 1 Chome, Ueno, Taito-ku, TOKYO, 110-8534 JAPAN 53002RM (KT)/72098HA (KT)/N228MO/2247TA, TS No.2439-1/4
