Datasheet RH3845MK (Analog Devices) - 4
Description | Radiation Hardened High Voltage Synchronous Step-Down Controller |
Pages / Page | 8 / 4 — ELECTRICAL CHARACTERISTICS: BURN-IN DELTA PARAMETERS. Specifications are … |
File Format / Size | PDF / 263 Kb |
ELECTRICAL CHARACTERISTICS: BURN-IN DELTA PARAMETERS. Specifications are at TA = 25°C. ENDPOINT LIMITS. DELTA LIMITS. PARAMETER
RH3845MW
ELECTRICAL CHARACTERISTICS: BURN-IN DELTA PARAMETERS Specifications are at TA = 25°C. ENDPOINT LIMITS DELTA LIMITS PARAMETER CONDITIONS UNITS MIN MAX MIN MAX
VIN = 20V, VCC = Boost = 10V, 1.222 1.244 V Reference Voltage SHDN = 2V, RSET = 49.9k, SENSE− = SENSE+ = 10V, SGND = PGND = SW = 0V −3 3 mV Rev. 0 4 For more information www.analog.com Document Outline Description Typical Application Absolute Maximum Ratings Package Information Table 1: Electrical characteristics Table 2: Electrical characteristics Electrical Characteristics: Burn-In Delta Parameters Electrical Test Requirements Total Dose Bias Circuit — Run Mode Total Dose Bias Circuit — Shutdown Mode Burn-In Circuit—Run Mode Package Description Typical Performance Characteristics
